Oil and Trans Temps - Ford Powerstroke Diesel Forum
Old 05-28-2010, 08:02 PM
Oil and Trans Temps
The gauges that are in the screen inside seem to be high. My oil temp has been reading at 190-203 and the trans temp has been 185-195. I thought these were very high. What is everyone else reading and how accurate are these gauges? This truck has 70 miles on it and its under no load in 80 degree weather. Thanks
Old 05-29-2010, 09:40 AM
194/204 6700 miles, does not vary much highway/city-am/pm....manic, depressed...high, straight.. still 194/204...
Old 05-29-2010, 12:40 PM
Haha ok. Well I guess I wont worry about it too much. These things are real nice and I cant believe all they can do.
Old 05-30-2010, 06:21 PM
Im seeing the same temps and thought the same thing. I called the service department and was told thats the normal operating temps.
Old 06-01-2010, 06:29 AM
If you think about it - those temps are very close to, if not exact to, the coolant thermostat. Prolly because the coolant is used to regulate those temps. With that said, it looks like your truck is doing what it was designed to do.
BTW, my temps run just like yours and they never vary even if I am towing. I was in some 100 degree heat this past weekend pulling my toy hauler @ 9.3 mpg and the temps were right there as always.
mowdoc
Old 06-01-2010, 11:39 AM
Im seeing the same temps as above also.
Old 06-04-2010, 09:22 AM
I tow a 14,000 LB 5th Wheel and my temps are running the same as the rest of the group.
Old 06-04-2010, 11:12 AM
Send a message via AIM to FastFocus
oil temps are normal, but wow. The trans temp seems hot to me. Granted i have a 6.0l with the 5R110, but my trans stays in the 150s unloaded, and 160's to low 170s towing, depending on how hard i am on it. I've never gotten hotter than 177, except for one time i hit 190.
