Any concerns with the 6.7 aluminum heads? - Ford Powerstroke Diesel Forum
Old 05-03-2010, 10:46 AM
anybody have any concerns with long time usage with the alum heads? is iron better? discuss...
Old 05-03-2010, 12:09 PM
Not with me. I had a 2001 Duramax with the shiney heads and they were never a problem. I had the truck juuuust a little over 600hp for a while too.
That Dmax engine had 48 head bolts just like the Scorpion does so clamping should be fine.
I would say that unless you start feeding exotic fuels or just get crazy with power enhancements, the heads will be a lifetime part on this Scorpion engine.
I will say too that the aluminum head will transfer excess heat away from itself faster than iron would. That should be a good thing I think.
mowdoc
Old 05-03-2010, 03:29 PM
Time will tell.
Old 05-04-2010, 06:29 PM
I'm pretty sure the powerstroke only has 36 head bolts. They claim that it has 6 per cylinder, but the 2 bolts between each cylinder are shared by those 2 cylinders. I don't know about the duramax.
