| General 6.7 Discussion General 6.7 Discussion |
28mpg 6.7 Ford Diesel on BIOG!!!!!!!!
This is posted on www.bobistheoilguy.com , forums section: oil analysis report: Used oil analysis diesel...(BTW, the dude put the WRONG oil in the new 6.7)
Ford 6.7L diesel (yeah, the new one) npauli Registered: 08/05/09 Posts: 16 Loc: Illinois miles on truck: 5537 miles on oil: 1708 oil type: Mobil1 10W30 SM/CF Cu 7 Fe 28 Cr 1 Al 3 Pb 0 Sn 0 Si 3 Na 5 K 4 Mo 88 Ni 1 Ca 2631 Mg 14 Zn 965 P 820 Soot 0 Oxidation 14 Nitration 7 Sulfation 18 Water neg Antifreeze neg Fuel 2.98% V100 9.9 This is not a normal UOA. Here's the story behind it: This truck is a member of Ford's press fleet to show off the new 6.7L diesel. Ford puts extra fuel in cylinder during DPF regen, and claims to be able to do so without oil dilution problems with B20. However, they do recommend using only 5W40 or 15W40 when running B20, but allow as light as 0W30 when running petro diesel. We did a little experiment to see for ourselves. The oil was changed at the start of the trip but the wrong oil was mistakenly used for fill (wasn't CJ-4). The truck was driven by a journalist/hypermiler I know from the press launch in Phoenix to Chicago with the goal of getting maximum fuel economy. That means very low speeds, loads, and temperatures. I think it went through a regen ~ 4-6 times, with total regen time of ~ 1 hour. It was also run on B20, so we might have been pretty close to the worst-case scenario for getting fuel in oil. He stopped by my house along the way and I pulled a sample and sent it in to a CAT dealer for analysis. More details of this trip can be found here: If you're curious, he got 28mpg on the trip. Questions for the experts: 1) Would you expect the wrong oil to have any effect on fuel in oil? 2) How much fuel in oil would make you nervous? Is 3% @ 1700 miles scary? 3) Would you expect results on the same truck 20k miles later to be any different? Perhaps the rings aren't "broke in" enough yet to seal properly. 4) If you were running B20 in this truck and doing UOA to set OCI's to avoid dilution problems, what values would you be watching? Just % fuel, or something else like viscosity? 5) Would you expect fuel in oil to keep going up ~ linearly under the same conditions, or would you expect it to slow down and approach an equilibrium? 6) I'm sure that the way this truck was operated is far from typical, but I have no idea how much less fuel in oil we'd see for more commong operating conditions (lots of idle time in the cold, for example). Have any guesses? _________________________ 2002 Duramax 4wd, 6spd manual 65k miles Last edited by Baddestt; 04-07-2010 at 01:08 PM. |
Pretty phenomenal for running B20, I heard that the mileage isn't as good with bio
. I have no idea about the rest of it though
I guess only time will tell
Hey - that was me!
I'm the same npauli. The 28mpg was from a hypermiler driving very slow w/ mirrors pulled in. The truck was a CCSB F250 4x4 with the 3.31 axle and a soft tonneau. Some more realistic numbers can be found here from running on the highway w/ cruise control at different speeds. Scroll towards the bottom. |
