Need a Smart Guy help with the DEF - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 9 Old 03-20-2010, 04:04 PM Thread Starter
Ok I understand that the DEF freezes around 12 degrees and that the truck has line and tank heaters that work with the key on. Here is my Question, I live in Alaska and the outside temperature is below 12 degrees for 3 months straight during a warm winter, so will the truck start and run long enough for the DEF to thaw?
2011F350SD is offline
post #2 of 9 Old 03-20-2010, 04:08 PM
shaking things up
jethro's Avatar
just wait till the tunes and deletes come out and get rid of that crap
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #3 of 9 Old 03-20-2010, 04:25 PM
late_99_PSD's Avatar
Quoted: 3 Post(s)
I'm 90% sure that the truck has to run for someting like 30 min, or X amount of miles before it starts using DEF, so it will have plenty of time to thaw.
Allen
1999.5 F-350 7.3, six-speeed
late_99_PSD is offline
post #4 of 9 Old 03-20-2010, 04:45 PM
def
There is a winter DEF go to -20F
bigbuckmiddaugh is offline
post #5 of 9 Old 03-20-2010, 07:34 PM
DEF is for reducing NOx emission, and NOx formation is very, very temperature dependent. A little hotter makes a LOT more NOx. So I guess it's reasonable that the truck might not need to use any DEF unless and until it's warmed up.
I wonder what they do to keep the freeze/thaw cycles from destroying the tank though.
'02 Silverado 2500
Duramax 6 spd ZF, 4x4
crew cab, long bed
npauli is offline
post #6 of 9 Old 03-21-2010, 05:28 AM
def
If it does freeze thaw. i wonder if they used a bladder like system.
post #7 of 9 Old 03-21-2010, 07:54 AM
I'm not worried about the DEF, Ford has tested it in cold weather. Can't wait for the tuners to get a hold of this.
jimchris is offline
post #8 of 9 Old 03-25-2010, 05:00 AM
Powerstroke Techie
Don't worry about it freezing. There is a tank heater, and line heater as well. The lines are emptied when you shut the key off.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #9 of 9 Old 03-25-2010, 06:38 AM Thread Starter
Like I stated in the first post i Understand about the line and tank heaters but they only work when the key is on, and all the testing in the cold was done to the trucks with them running 24/7, if the truck sits for 8-12 hours at night in sub zero temps it will take the tank some time to thaw. What I want to know: is there enough time from when the tank is fully frozen untill thaw to drive the truck with out an idiot light or other issues.
