| General 6.7 Discussion General 6.7 Discussion |
2011 F-450
Lately I have been reading around on an information I could find on the new Super Dutys. On almost every forum people are picking apart the new F-450 because it has smaller tires, 4.30 axle, smaller brakes, etc. Basically calling it a Wide Track F-350 Tow Boss Dually and that it is now sissified.
Ford says that it retains the same GCWR of 33,000# from the 2008-2010 model years too. So my question is this, well more like a gripe. How the hell does anybody know this new F-450 is sissified if no one has driven a damn trailer with it yet, let alone cranked one over and strolled down the road. To me it seems the Ford engineers are just using better technology to keep the same capacities, but make it more fuel efficient. Seems like the 6.7L and the Torq6 are doing their job. Probably MUCH better engine braking to aid the smaller breaks too. Last edited by kramocramed; 12-24-2009 at 10:54 PM. Reason: icon fix |
The PICKUP version of the F450 has the less gear and tire and all that, mostly for mileage I hear...
The CAB & CHASSIS F450 will be the full monty heavy assed truck. Heavier, deeper gears, etc. |
I was thinking about this tire size change.....
Wouldn't you loose GVW capacity with the smaller (E rated) tire? I don't remember what the capacity is on the 19.5 (F rated) tire is but wouldn't this pose a problem if say you are actually using the truck to full capacity and got pulled over by the DOT and they hassled you because you were over weight on your tires.....(it happened to me hauling cars, I was 400 lbs over.... he let me go) |
I think the GWV is a bit less on the pickup version..same as with the F350 pickup vs the cab/chassis F350..
they are different
![]() ![]() The only difference between the current 450 pickup and 350 are the things I mentioned earlier. The 450 chassis cab has a beefier frame and springs.
I heard the main reason for going to 17" wheels is for a higher speed rated tire.
Well for one thing going down in wheel/tire size allows you to use higher gears to equal same overall gearing correct? For example 35" tires with 4.88 gears might be close to 32"s with a 4.30.
Buy with confidence
As a a owner of the previous 09 F450 and a owner of the current 11 F450 I will tell you that in every way the new one trumps the previous "civilian" 450. My first was rough as heck and pulled decent but just felt like something was missing. My new one rides like a caddilac with out a load and even better with it. I have had no issues with over loading the tires but i will say the most ive had on it was 28656# but i pulled that from Louisiana to Colorado without a hiccup. I would see no problem with pushing it to its limit confidently. Ford bread til I'm dead.
It will handle what it is rated for. Big tires ride bad and cause poor economy.
