I purchased some Flat 4" ready lift blocks for my 15 Crew Cab short bed F250, that has a one piece driveshaft, and after installing them the truck seems to have developed a little shudder under acceleration. I crawled under the truck and took a picture and the pinion angle is off some but it doesn't seem like it would be enough to cause that. I also installed some Nitto Terra Grapplers 295/65r20 and I've had those balanced 3 times just to make sure there wasn't an issue with the tires. I talked to readylift about it and they sent me some tapered blocks to put on but I'm afraid it will change my pinion angle to much the other direction. I'm just looking for some advice from anybody that has the same setup and if you have pics that would be great. Did you use flat or tapered? Do you have a shudder?
Thanks in advance.
Here is a look at my pinion angle with the 4" flat blocks from Readylift.
That did cross my mind but i'm also experiencing the shudder from 55 to 70 under light acceleration as well. It would be a good excuse to go ahead and pull the trigger on traction bars though.:woot:
Do you have any pictures of the truck with the 4 inch blocks installed. I need to do this to my truck ASAP I can stand the sag when Hooked to even a small trailer
I have the tapered ones from ready lift in my hand but the taper just looked so aggressive I was afraid it would offset the angle even more the other direction. But there's only one way to find out so I guess I'll be swapping those out this weekend.
So I got the tapered blocks installed today and I like the look of the pinion angle now BUT I'm still getting the same shudder around 60 mph. It didn't help at all so now I'm back to square one. I'm wondering if I have a tire that has a defect from the factory? I've had them balanced 3 times since I purchased them 2 weeks ago and nobody said anything about seeing a defect but idk what else it could be. I'm out of options. If anybody has any advice I'll take it.
This is with the tapered blocks. It looks a lot straighter.
So i have a 6.0 250, CCSB w/ 2 peice DS. I added F350 4" blocks and it messed w/ my pinion angle and i now have a shudder on take off. I did this to avoid the expense of bags pulling my camper. I think im going to put the 2" blocks back in and just run w/ airbags instead.
However. PMF Suspensions. has a " driveshaft carrier bearing spacer/angle " kit that could help w/ that. Not on your truck w/ the single axle but maybe the extra angle w/ the flat block on a sngle DS means u need the angled blocks?
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
