I recently replaced the leaking inlet tube and connector. That is all good with no leaks. Looking with a mirror I am seeing some seepage on the back right of the turbo (left if you are facing truck). Is there another connector on the back side or could the seal be worn? Ive searched and all I have seen was in reference to the inlet tube leaking.
Is there a diagram showing the travel of coolant?
Trying to decide if I should knock it out or ride it out until I swap turbos
Thanks in advance
Thanks in advance
