question: my check engine light has come on. Diagnostic code says p2183 which lists as : engine coolant temperature sensor 2 circuit range/performance.
Is this a common code to appear on these trucks? [ 2011 ] Could this be a loose wire to the sensor or something as simple as that? I haven't looked too close under the hood but thought I would ask here first. thanks
