Ranch Hand or like bumper lamps - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-05-2014, 07:20 AM Thread Starter
Quoted: 2 Post(s)
Do you guys have the big white lamps on the Ranch Hand wired to a switch or to the reverse lamps? If you have them wired to the reverse lamps, how did you wire them? Did you put a smaller bulb in the factory lamp location?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 3 Old 08-10-2014, 08:23 PM Thread Starter
Quoted: 2 Post(s)
Anyone?????
wreedPS is offline
post #3 of 3 Old 08-11-2014, 07:49 AM
IronCobra's Avatar
Quoted: 9 Post(s)
I would suggest you wire them in addition to your factory reverse lamps. I would also suggest you use LED bulbs in the bumper as they will draw far less current and you can simply tap into your reverse wires from the light or from the trailer connection. I don't have a ranch hand, so I couldn't tell you specifically. though.
2016 F450 Platinum FX4 CC LWB
2016 Chaparral 360IBL Fifth Wheel: 15,500lbs
GONE - 2011 F250 FX4 6.7L Lariat Ultimate
IronCobra is offline
