Towing machine! - Ford Powerstroke Diesel Forum
 3Likes
  • 2 Post By bruteforcerider
  • 1 Post By bruteforcerider
post #1 of 8 Old 08-05-2014, 03:35 AM Thread Starter
bruteforcerider's Avatar
Towing machine!
First big trip 2014 F250 6.7. Pulling 40 ft fifth wheel. Topped jellico mountain in tennesee running 65 with pedal to spare!
"Stroker 8" and Leclerc457 like this.
bruteforcerider is offline
post #2 of 8 Old 08-05-2014, 04:46 AM
Tweez's Avatar
Quoted: 8 Post(s)
Amen to that, these things are pulling machines.
Tweez is offline
post #3 of 8 Old 08-07-2014, 04:05 AM Thread Starter
Averaged 11.5 pulling about 13, 000 lbs. Thought that was good.
"Stroker 8" likes this.
post #4 of 8 Old 08-07-2014, 01:59 PM
Vannnce's Avatar
Quoted: 13 Post(s)
is that all a 40'er weighs these days? Amazing how much weight they can shave off. Mine measures right about 34' and it weighs 13k easily. loaded to the gills though..
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #5 of 8 Old 08-07-2014, 02:22 PM
Quoted: 4 Post(s)
They tow even better once all the EPA crap is removed...
2013 F250 6.7 PSD
Crewcab FX4 6.5 ft bed
Factory 18" Michellins 3.55 gears
DPF and EGR delete 51" muffler
Punch it Performance tunes
Deerhunter4 is offline
post #6 of 8 Old 08-07-2014, 05:24 PM
fordtrix's Avatar
Mine is a 42' and probably around 16k. Tows like a beast. Engine has tons of power, only worry sometimws is the tongue weight and the srw.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #7 of 8 Old 08-07-2014, 09:42 PM
It all depends on what it's made out of... real cabinets...type of flooring...ceiling construction...etc. The total weight isn't as much of a concern as the pin weight.
Dougstdig is offline
post #8 of 8 Old 08-08-2014, 03:22 AM Thread Starter
10, 900 dry weight, max gvw 13, 800. I am considering a air ride pin box to smooth out the ride.
