2011 F350 Lariat CCLB FX4 - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 08-02-2014, 01:54 AM Thread Starter
My truck sometime makes a buzzing noise after I shut it off. It sounded more like a pump. Not sure exactly what it was. It drives fine, gauges are all normal.
I bought this truck used about a month and half ago. It came with H&S Mini. I leave it a performance all the time because I find the transmission shifts better in performance mode.
Where do you guys think the noise is coming from? Thanks for any info that you guys can provide.
RL
The_Badge likes this.
Rambilt is offline
post #2 of 11 Old 08-09-2014, 03:01 AM
Any update on this???
I was told that this was the Urea being transferred back into the tank.... lol
I didn't believe that for one minute, but who knows?!?!?!?!
I'd love to know what you figured out
The_Badge is offline
post #3 of 11 Old 08-09-2014, 04:02 AM
NotQuik's Avatar
Mine does the same thing. Truck did it stock and still does it deleted.
NotQuik is offline
post #4 of 11 Old 08-09-2014, 06:21 AM
Quoted: 4 Post(s)
Same here. Mine did it stock and still does it deleted. I heard a new 2015 doing it the other day. I'm not too worried. It is kind of weird though.
2013 F250 6.7 PSD
Crewcab FX4 6.5 ft bed
Factory 18" Michellins 3.55 gears
DPF and EGR delete 51" muffler
Punch it Performance tunes
Deerhunter4 is offline
post #5 of 11 Old 08-09-2014, 06:27 PM
RJC2's Avatar
Quoted: 368 Post(s)
Mine has done it since day one. That clicking noise sounds like a revolver hammer being pulled back. I hope I soon get used to it, it scares the pooey out of me everytime! (I've been shot at a time or two)
2017 F350 CCSB King Ranch Ultimate 6.7
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler, CTS Insight monitor,
RJC2 is offline
post #6 of 11 Old 08-09-2014, 07:02 PM
HighHP's Avatar
DEF tank purging the lines. Once the truck turns off it sucks the fluid back into the tank, stuffs really corrosive so it helps the lines live a little longer. Plus if you live in colder climates it will freeze and blow up all the lines.
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
The Following User Says Thank You to HighHP For This Useful Post:
The_Badge (08-10-2014)
post #7 of 11 Old 08-10-2014, 02:00 AM Thread Starter
My truck is a daily drive back and forth to work 40 minutes or so one way. The buzzing noise doesn't happen in the morning only in the evening when I get home in the peak of heat around 5:30PM. Seems like I'm not the only one experiencing this noise. It does it only once in a while when it's really hot. I love this truck though. I'm getting 17MPG city/highway combined. I drove it to Oklahoma, got 20MPG.. Awesome for a HUGE truck... LOL! I haven't tow my 31' travel trailer yet but I can't wait.
How would I know my truck is EGR or DPF "deleted"? Thanks!
Rambilt is offline
post #8 of 11 Old 08-10-2014, 03:47 AM
HighHP's Avatar
If the truck doesn't get up to full operating temp in the morning commute then the DEF won't start dosing so then no need to purge the lines.
As far as deletes go, if you look under the truck your exhaust will be a normal tube front to back or a 6 foot long odd shaped canister looking thing. That's a good start. And it'll have a tuner if it's deleted.
HighHP is offline
post #9 of 11 Old 08-10-2014, 04:06 AM Thread Starter
Hi HighHP, my truck came with H&S Mini when I bought it also it doesn't have a catalytic converter.... Exhaust is a straight pipe except for a small odd looking muffler. LOL...
Rambilt is offline
post #10 of 11 Old 08-10-2014, 05:55 AM
Quoted: 4 Post(s)
Sounds like you are deleted then.
2013 F250 6.7 PSD
