Re-Gearing: Is it worth it? Derp. - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 68 Old 07-31-2014, 04:52 PM Thread Starter
POWERCHOKER
Dantron's Avatar
I went over to 4 Wheel Parts and received a quote of $2700 for 4.11's, parts, labor, and extended warranty. I have 38's with 3.55's right now. I may do 4.27's, but not sure. The parts catalogue recommended higher than 4.88's, which seemed kinda strange but it was also recommending 3.55's for tires smaller than 30" or maybe even 25", I can't remember exactly. They only sell "G2" gears...
Anyway, is it really worth almost $3,000 to change gears? How much of an improvement will I notice? Which ratio is best for me? Are "G2" gears any good, or perhaps bad? Thanks...
Dantron is offline
post #2 of 68 Old 07-31-2014, 05:01 PM
66Bronco's Avatar
For somebody who knows what they're doing, $1000 per axle is not uncommon.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #3 of 68 Old 07-31-2014, 05:26 PM Thread Starter
POWERCHOKER
Dantron's Avatar
Hmm. Yeah $2650 was higher than I expected, it's $2450 without the warranty. I better shop around some...
Dantron is offline
post #4 of 68 Old 07-31-2014, 05:44 PM
Ramathorn's Avatar
Quoted: 2 Post(s)
I just picked up my truck today from 4wheel parts after getting a 6" lift with 37/13.50/20's.
I have the 3:55's and I honestly didn't notice much difference. I haven't pulled my toyhauler yet, but I think unless you tow often , it may not need gears. Going from a stock 34" to a 37" or even a 38" isn't big enough jump in my opinion, but that's just me.
This Diesel engine rocks. Not like the old days of a 1/2 ton gasser with stock 31's or 32's and going to 38's. Had to definitely re-gear then.
Ramathorn is offline
post #5 of 68 Old 07-31-2014, 05:46 PM
Heavy_GD's Avatar
Quoted: 1645 Post(s)
Feedback Score: 3 reviews
Regardless of the gearing argument... IMO if you don't do a locker/tru trac while you are in there then you are wasting labor money.
GoFastPadre and Cheap6.7 like this.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #6 of 68 Old 07-31-2014, 05:54 PM
Quoted: 28 Post(s)
Not really an apples to apples comparison on trucks or usage but I have G2 gears in the rear of my ranger (G2 doesn't make a reverse cut gear for my front axle) and its taken some abuse on hills and rocks. Hopping and bouncing around and broken a shaft or two but no gear issues. A local transmission shop charged me 200 bucks labor per axle. Sounds really cheap but they've done 4 axles for me and all are still good. When I checked with 4 wheel parts they were about 450 an axle labor only. Hope that helps a little.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #7 of 68 Old 07-31-2014, 10:30 PM Thread Starter
POWERCHOKER
Dantron's Avatar
Thanks guys. That was all useful information. Ramathorn, I know what you mean about not noticing a difference. I've driven on 35's, 37's, and now 38's and I haven't noticed any losses. I probably won't be doing much towing. I've read a good deal of hype on re-gearing, but it's not enough for me to drop $2000 on it. I can do more effective mods with that money...
Dantron is offline
post #8 of 68 Old 08-01-2014, 09:07 AM
Baddestt's Avatar
Quoted: 9 Post(s)
It really doesn't become a big issue until you tow...the 6.7s have good power, but it works harder turning big heavy 38s with 3.55 gears. And like stated previously, it really is a waste to do JUST gears and not do a detroit locker rear/truetrac front while getting gears done at same time.
For $2900 OTD (tax, parts, labor) at 4 wheel parts austin: front detroit true-Trac with 4:10 gears, full installation kit. Rear detroit locker with 4:10 gears and full installation kits. I provided them with the Amsoil gear lube, that's it. And I got $120 rebate through Eaton for the differentials since they were running a 30-day rebate special in March of this year.
So far, it's been flawless...pulls like a freight train and virtually unstoppable off road
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, Barder '03 turbo rebuild w/RR billet wheel, SCT SF3 tuner, F-Detroit Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, LT315/70r17 Duratracs, Amsoil Gear lube, Delo 400 LE 5w30 diesel, Delo ELC, archoil, bpd ficm, BPD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
The Following User Says Thank You to Baddestt For This Useful Post:
Heavy_GD (08-01-2014)
post #9 of 68 Old 08-02-2014, 05:56 AM
I regeared mine to 4.30 with 8" lift and 22/37s love it. I prob shouldof prob done 4.10s. I may put 38s later.It pulls like a train! My truck runs about 350 more rpms than stock. It runs about 2,000 rpms at 72 mph. My main reason for gears was power and i didn't want any strain on my tranny. Mine was about $3k, Yukon 4.30s,Amsoil,front/rear Mag Hytec diff covers.
IRATTLE is offline
post #10 of 68 Old 08-02-2014, 08:40 AM Thread Starter
POWERCHOKER
Dantron's Avatar
When you guys say it pulls like a train, do you mean towing or normal driving? For instance, what kind of difference would I notice accelerating from a complete stop?
Dantron is offline
