65 gal Titan tank after removing DEF tank? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-31-2014, 05:35 PM Thread Starter
TX_TRU_STUD's Avatar
Quoted: 52 Post(s)
Can you get the large long bed titan tank for the newer super duties if you remove the DEF tank if you deleted? Will it fit?
I have a F250 with all the DEF and what not stock, but I watned to know from you guys who deleted and removed the DEF tank, can you fit the larger tank?
Does that make sense?
TX_TRU_STUD is offline
post #2 of 5 Old 07-31-2014, 09:26 PM
Why would they sell it if didn't fit? You don't need to delete it either. Or are you trying to fit a long bed tank in a short bed?
ToyHoarder is offline
post #3 of 5 Old 08-01-2014, 01:45 AM
What's a "what not"?
Dougstdig is offline
post #4 of 5 Old 08-01-2014, 03:07 AM
Quoted: 71 Post(s)
The Titan tank and others are molded/built to conform to the shape of the upper mounts. You could make a bunch of hacks to get it bolted in but would it be safe? Would the fuel lines connect? I highly doubt it in both cases.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #5 of 5 Old 08-01-2014, 08:30 AM Thread Starter
Quoted: 52 Post(s)
Sorta, I am just asking if someone who has deleted which means the DEF tank is gone, can they fit a long bed tank on a short bed truck now that there is more room. Would it fit without crazy mods making it work? I would think it might fit since you would have more space forward.
