Am I going to blow my tank up? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-28-2014, 08:14 PM Thread Starter
Ryan2012F350's Avatar
Garage
So heres the deal, last week I had a factory tank and an aux tank gravity fed, when I opened the cap when i had previously filled it there was a very slight bit of pressure on the cap but nothing that worried me.
Fast forward to this week, now I have a titan tank and put a new pump/filter setup on the aux tank since it would take 8 hours to feed gravity haha. See pic.
Now this is a small Airtex pump 72 GPH, 4-6 PSI, I filled about 30L today just to check it all out and had a bit more pressure behind the cap of the titan tank (body tank) when i opened it up. It was a decent little puff, but hard to say how much pressure it was.
Do these tanks have a vent at a certain PSI? is the cap a 1 way vent? Am I going to wreck my tank or anything else?
Thanks!
F350less for now.
Ryan2012F350 is offline
post #2 of 16 Old 07-28-2014, 09:54 PM
Str8Ugly's Avatar
my factory tank always has some pressure behind it and i dont have anything else going into it
2011 king ranch f350 cclb 4x4, 6" lift, 20x10 fuel mavericks, 35" toyos, billet grille, ranch hand rear bumper, SCT X4 with PIP tunes, Sinister egr delete, flopro dpf delete pipe
2002 f250 ccsb 4x4
6" pro comp lift kit, 20x10 eagle 064's, 35" trail grapplers, 2007 front clip, Harley Davidson Headlights, Bull nose bumper, Ranch Hand Rear Bumper, dfuser harness, 6637 air filter, straight exhaust, foil delete
Str8Ugly is offline
post #3 of 16 Old 07-29-2014, 02:49 AM
Quoted: 81 Post(s)
A little pressure is not a problem with the tank as long as it is not excessive. The tank is most likely designed to expand some.
You definitely want to avoid a vacuum. A vacuum could collapse the tank
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #4 of 16 Old 07-29-2014, 07:20 AM Thread Starter
Garage
Thanks guys I agree a little pressure is ok, just hope its not too much.
Anyone know of a fuel cap that releases at like 5 PSI and also releases for even the smallest amount of vacuum?
F350less for now.
post #5 of 16 Old 07-29-2014, 03:24 PM
brendan.9's Avatar
there must be some pressure when i did my tank and accidentally broke a tab tried to just zip tie it to hold well there was no pressure and it sucked in snow. I had to get a new tab and now there is pressure again so if you loose that means its probably sucking from somewhere and letting stuff you don't want in like snow!
2013 F350 5" straight exhaust, Mini Maxx, CAI, H&S egr delete
03 SVT Cobra Whippled 632 rwhp 572rwtq Torch red 10th Anniversary coupe.
brendan.9 is offline
post #6 of 16 Old 07-29-2014, 04:01 PM Thread Starter
Garage
That sounds right to me, wish I knew what kind of pressure they are meant to hold and I could T off the Titan tanks Vacuum vent line and have a 3-4 psi check valve for over pressure, might be redundant but for $20 i'd go for it.
F350less for now.
post #7 of 16 Old 07-29-2014, 04:13 PM
Something doesn't sound right here...or maybe I've misunderstood...
I have a RDS tank is a gravity fed unit that feeds into my truck's tank via a T-fitting that has a 1 way valve built into it. There's also another line leaving the top of the take that is a vent line...it also has a 1 way valve to prevent spillage in the event of a rollover. Never have I ever had any pressure. I would contact the manufacturer ASAP to assure there's not an issue. It's not something to play with.
Dougstdig is offline
post #8 of 16 Old 07-29-2014, 04:14 PM
ZMANN's Avatar
Quoted: 1670 Post(s)
funny question
I did my Titan tank and actualy added i more vent using a PWC vent valve that keeps a few psi but no vacuum
i am pretty sure the OEM is the same the reason I did mine was to get full flow at the pump without the nozzle shutting off and it works
but i think your fine without anything since the OEM is vented and while filling this would exceed your pumps transfer volume and it doesn't spit back up from the filler so i imagine the vent is expelling the air being displaced just fine
We Miss you Ronnie
ZMANN is online now
post #9 of 16 Old 07-29-2014, 04:47 PM Thread Starter
Garage
ZMANN your right on track I think, but I think the factory tanks now are only vacuum vented due to emissions controls where it's not allowed to vent fuel vapours into the air.
Having said that, I like where your going with the PWC vent valve and it would be awesome if you could show me a similar valve! My idea is to T the factory vacuum vent line, one side of T has factory (titan) vacuum vent and the other will have my own pressure vent at 3-4 PSI.
With that setup when I am pumping fuel into the titan tank at 72 GPH it won't allow it to build more than 3-4 PSI, while when I'm not pumping it will act as normal with just the vacuum vent.
Aside from that the aux tank has a vented cap for both vacuum and pressure so it should be good to go.
F350less for now.
post #10 of 16 Old 07-29-2014, 04:57 PM
ZMANN's Avatar
i would have used a vent from a Yamaha since I have 3 of them LOL
I know I installed a vent valve of some type i need to go peak and make sure that's what I used
i also extended it up to the very top of the inside of the bed above the fill neck
We Miss you Ronnie
ZMANN is online now
