Crazy reverse sensors on ranch hand - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-23-2014, 06:58 PM Thread Starter
Quoted: 2 Post(s)
Anyone else reverse sensors throw alot of false positives? I have a ranch hand rear replacement. They will go off solid when clear as day nothing is behind me. If I roll a little bit they go off and back on screaming at me.
I have noticed the rubber is all ate up around Them.
Anyone else have this problem?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 9 Old 07-24-2014, 10:54 AM
79_bronco's Avatar
I have similar problems with mine too. Sometimes they work and other times they go off on pot holes or any type of thing behind me. Now days I just ignore it and use the camera.
2012 F-250 Lariat Crew Cab Short Bed 4x4 FX4
Ranch Hand Front and Rear
30in Rigid E Series Light
Bilstein 5100 Series Shocks
Truck Cover USA American Work Cover with Toolbox
Kenwood DNX570HD Head Unit
79_bronco is offline
post #3 of 9 Old 07-24-2014, 11:03 AM Thread Starter
Quoted: 2 Post(s)
You have ranch hands also? I was thinking about replacing mine, but it all started with the ranch hand. wish you could just turn the damn things off.
wreedPS is offline
post #4 of 9 Old 07-24-2014, 11:23 AM
79_bronco's Avatar
I have a legend full front replacement and a legend rear as well. Mine were a bit flakey before I put on the ranch hand. I haven't found a good way to test them though to start replacing them sensor by sensor.
post #5 of 9 Old 07-24-2014, 12:35 PM
Quoted: 3 Post(s)
My reverse sensors seem very reliable and accurate. Been very happy with them.
2012 F-350 Lariat CC SRW 4x4
Leveling kit with 35" Nitto Trail Grapplers
EskimoPie is offline
post #6 of 9 Old 07-24-2014, 04:58 PM
Alberta Advantage's Avatar
Quoted: 19 Post(s)
Had it happen on my '09. Replaced 2 out of 4 sensors and back to normal. These sensors are apparently very sensitive if nudged or moved without extreme caution and care or put back correctly. They're pretty pricey too from the dealership.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #7 of 9 Old 07-24-2014, 05:46 PM
Dirtboy64's Avatar
Quoted: 4 Post(s)
Mine go off constantly for no reason,and i have a stock bumper
Dirtboy64 is offline
post #8 of 9 Old 07-27-2014, 06:23 AM Thread Starter
Quoted: 2 Post(s)
Does the ranch hand rear replacement use their own retainers to hold the sensors or does it use the factory ones?
I didnt install my rear bumper, which is why I ask.
wreedPS is offline
post #9 of 9 Old 08-05-2014, 08:19 AM Thread Starter
Quoted: 2 Post(s)
Do you guys have the big white lamps on the Ranch Hand wired to a switch or to the reverse lamps?
wreedPS is offline
