Titan Fuel tank On its way. 2015 F350 - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 31 Old 07-23-2014, 04:17 PM Thread Starter
A8050266's Avatar
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
All,
I decided to pull the trigger on a Titan 50 Gallon Fuel tank for my 2015 F350.
Its on its way to me...
If anyone has any questions about my pending install. Im glad to try and answer.
Their are plenty of threads regarding Titans tanks. and Im sure you can probably
find your questions answered already.
Ill be doing the install myself. and having read thru most of the posted threads.
I think the Install should go quite easy.
Rational for buying the tank:
Having come from an 08 that got avg 15/22 with a 30 gallon tank.
and now getting 10/15 with a 25 gallon tank.
The frequency of stops at the fuel station are really getting me down.
Also my immediate location isn't very Diesel friendly. Often I find my self
pulling into stations that do not carry diesel. This to is frustrating.
So, the solution for me is a bigger tank. less stops. and lends itself to smarter purchases.
often when diesel is cheaper I wish I could buy 100 gallons. etc...
I intend on trying to add to the plethora of information regarding the tank and its install and the dealer interaction.
Im pretty excited to be getting this finally! from all the posts i have read. TITAN is the Benchmark all other tanks are measured by.... And though it may seem pricy. my SD came in at about 60K... whats another 1K?
-=Sam
813.390.0040 / Sales, engineering, and floor sweeping. (mostly the sweeping)
2015 F350 CC FX4/Lariot SWD Platinum white
A8050266 is offline
post #2 of 31 Old 07-23-2014, 04:27 PM
Quoted: 3 Post(s)
I may go with this also on my 2015 250. I hope you can post some pix. Good luck with your install. Sounds like you got it all covered.
Storm95 is offline
post #3 of 31 Old 07-23-2014, 04:43 PM
Heavy_GD's Avatar
Quoted: 1310 Post(s)
Feedback Score: 3 reviews
Congrats, I think a titan is on most of our wish lists
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #4 of 31 Old 07-23-2014, 05:17 PM Thread Starter
A8050266's Avatar
Yea, on My prior truck the 08 f250... I wished for a Titan....
took me my 15 with horrible mileage to finally get one!
-=Sam
A8050266 is offline
post #5 of 31 Old 07-23-2014, 05:29 PM
ZMANN's Avatar
Quoted: 1338 Post(s)
from experience I found it was worth pressurizing the tank to 5 psi and doing a soap test
around the sender
a few plugs and looped hoses make it easy fuel leaking out of a sender gasket stinks LOL
We Miss you Ronnie
ZMANN is offline
post #6 of 31 Old 07-23-2014, 06:35 PM
I wanna do this I'm just nervous about not getting it sealed right and water getting into the tank. I noticed my dealer had some titan banners in their showroom. Makes me wanna ask if they'd warranty the install. I don't really wanna part with $1500 though.
ToyHoarder is offline
post #7 of 31 Old 07-23-2014, 07:29 PM
Ryan2012F350's Avatar
Garage
Got one going in Monday, hopefully it goes well. Not installing myself due to lack of time but i'm pretty pumped.
2012 F350... Problems so far: Rear pinion seal, rad split, U-Joints, Waste gate tubing TSB.
4.5" Carli Lifted, 2.5" Kings, 37" Toyoed, Carli bagged, Wireless compressored, 5th hitched, rigids on both ends, slip tanked, titan tanked, upfittered, 12v pumped. Last truck I'll ever own.
Ryan2012F350 is offline
post #8 of 31 Old 07-23-2014, 08:19 PM
Quoted: 66 Post(s)
I had a buddy install my Titan 65 gallon tank this past weekend. It had been sitting in the shed for almost 4 months awaiting the truck to arrive after I ordered it in early March. I found it on eBay for $1150 shipped and it was new.
Install went fairly well except on the CCLB, we had to notch the center Titan tank bracket to clear the driveshaft hanger bearing.
Like mentioned above, I did a soap test on the pump after installing and torquing to 30 ft/lb. I did lightly coat the rubber o-ring with diesel fuel prior to tightening the nuts. No leaks from soap test and we probably put 20-30 air pressure into the tank.
Have covered about 35 miles since install and Miles to Empty still reads 999...lol..I did have the dealer change the Miles to Empty to compute on 65 gallons prior to me paying for truck. Also had them turn on the Daytime Running Lights also.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #9 of 31 Old 07-23-2014, 08:48 PM
Originally Posted by A8050266 View Post
All,
Here's a video that may help.
2011 Ford Super Duty Titan Fuel Tank Installation - YouTube
I added a 51 gallon tank to the bed of my truck and I think they're made up to 90gal... It has a shallow took box on top that locks and it's all below the top rail of the bed. I have a tri-fold cover on top and you'd never know it's there.
Auxiliary-Transfer Tank: Fuel Toolbox Combos | Auxiliary Fuel Tanks, Transfer Fuel Tanks + Skid Fuel Tanks | Fuel Transfer + Lubrication | Northern Tool + Equipment
It splices into the main fill tube and works like a charm. I can if it weren't for Dr. Pepper's and having to stop... I could make it from Miami to nearly Dallas. I had to stop at the rip griffin just outside the 635 loop... Unloaded of course but I definitely stock up when I find a location on the cheap... providing they get a lot of traffic.
If you wouldn't mind, could you take measurements and photos of the stock and modified distances below the frame rail and from the ground??? Thanks in advance...
Dougstdig is offline
post #10 of 31 Old 07-23-2014, 09:50 PM
Quoted: 11 Post(s)
I just installed a 50g Titan tank a few weeks ago. Went fine and it's awesome having the range, especially for towing. Search my name for my review on how it went.
Drewtk is offline
The Following User Says Thank You to Drewtk For This Useful Post:
pjcinmi (07-22-2015)
