Aluminum savings!! - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 35 Old 07-22-2014, 08:11 PM Thread Starter
Quoted: 244 Post(s)
Aluminum savings!!
So I'm just going to copy/paste my post from another forum so it may be repetitive for some.
Kind of off topic since it isn't a 6.7 BUT it is important to know and I think can stir up some good discussions on the 17 Aluminum SD.
Ford just announced today that a 2015 F150 CC Lariat is coming in at 732lbs lighter then the 2014 equivalent!!! It's weight is 4942lbs!!!
Ok, so here is the interesting point.. if they saved that much weight with Aluminum, what do you think we will be seeing with the 17 SD weight savings? Heavier/bigger truck should equal bigger weight savings.
Have to give credit for the article but it is confusing and poorly written.
2015 Ford F-150 Weighs Less Than 5,000 Pounds, 2.7 V6 Makes 325 HP
So with a 15% weight savings on the F150 and if Ford can do that with the Superduty, we could be looking at UP TO 1,000lbs of weight savings. With more gears in the upcoming tranny, we could see some significant fuel mileage increases.
Boy GM is going to be 5+ years behind!!!
Thoughts?? Let the discussions begin.
15 6.7 F350 CCSB 4x4 Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2, Dieselsite fuel filter, DeeZee tailgate assist, Hellwig Rear Sway bar, Bilstein 5100s
**Support the Online Vendors!!! Want your best price, buy from Scott Pratt!! Get your truck in 3-4 weeks, order to delivered!!
blwnsmoke is offline
post #2 of 35 Old 07-22-2014, 08:29 PM
RJC2's Avatar
Quoted: 311 Post(s)
GM seems to be really lagging behind lately, and doesn't appear to care. I guess with over 29 million recalls, they have their plate full.
pops250, 6.0newb! and 977300 like this.
2017 F350 CCSB King Ranch Ultimate 6.7
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler, CTS Insight monitor,
RJC2 is offline
post #3 of 35 Old 07-22-2014, 08:43 PM
If they do I would have to rethink my purchase opitons. I do not think Aluminum body panels will be near as durable. An interesting thing to consider here. Body shops are not prepared to work on aluminum. I've read articles insurance will go up 15 to 25%.
Dougstdig is offline
post #4 of 35 Old 07-22-2014, 09:11 PM Thread Starter
Quoted: 244 Post(s)
Ford claims 10% and they have already begun trainings on repairs with dealerships. As more and more vehicles turn to aluminum, it will become more common. Aluminum vehicles have been out for many years, it is nothing new.
Also, if you havent seen them, go to youtube and search for torture testing of the 15 f150. Pretty amazing videos (10 of them). I am not worried about the aluminum, mining companies have been testing it out without even knowing about it.
post #5 of 35 Old 07-23-2014, 04:19 AM
Ontario Trucker's Avatar
Once again I agree with Bman^^^^
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
post #6 of 35 Old 07-23-2014, 04:26 AM
RJC2's Avatar
Quoted: 311 Post(s)
You have to remember that this is an aluminum alloy that Ford is using. It's actually harder than regular aluminum from what I've been reading. One Ford informational video said that they are using the exact same alloy that Boeing uses on the new 787 Dreamliner's wings.
That jet can weigh as much as 557,000 lbs. and travel at Mach .85, so I think the durability issue is... well, a non-issue.
RJC2 is offline
post #7 of 35 Old 07-23-2014, 04:28 AM
The only thing that concerns me is the salt up here unless there is a cure
post #8 of 35 Old 07-23-2014, 05:44 AM Thread Starter
Quoted: 244 Post(s)
Why would salt be an issue? Salt rusts on steel, it doesn't on aluminum. I would think Aluminum would be better then steel.
post #9 of 35 Old 07-23-2014, 06:36 AM
NotQuik's Avatar
Weight savings on a Super Duty....I'm interested to see how that might effect towing capacity.
Brian
2006 F250 FX4 Lariat
2.5" ProComp Spacer, OEM F350 blocks, Cat Delete.
NotQuik is offline
post #10 of 35 Old 07-23-2014, 06:41 AM Thread Starter
Quoted: 244 Post(s)
Weight savings isn't going to have an effect on towing. The weight savings is in the cab, bed, doors and fenders. None of that effects towing.. Towing is more of the frame and suspension.
One of the comments on the F150 is that the 2.7ecoboost in the F150 allows it to tow 8,500lbs which is just insane out of a 2.7. No mention of the 3.5 eco yet for tow ratings that I could find.
