37's and gearing - Ford Powerstroke Diesel Forum
 9Likes
post #1 of 37 Old 07-21-2014, 09:59 PM Thread Starter
Y&R0864's Avatar
37's and gearing
So I just bought a used 13' f250 and it came with a 6" lift and 37's. Definitely does not feel like the gears were redone after the left.
Can anyone help me out on what gears I need to compensate for the tires and allow this truck to run properly?
Also, what will I need to make the computer be alright with the gear change?
And lastly, will changing the gear void my powertrain warranty?
*BigBlack* likes this.
2008 F250 6.4 crew cab lariat w/s&b intake, flo pro egr delete, diamond eye 4" turbo back, and mini max
Y&R0864 is offline
post #2 of 37 Old 07-21-2014, 10:00 PM Thread Starter
Y&R0864's Avatar
Just thought I would upload a picture so y'all can see what I'm working with.
Y&R0864 is offline
post #3 of 37 Old 07-21-2014, 10:01 PM Thread Starter
Y&R0864's Avatar
And do trucks with 37's tow fine? I have to move a 5th wheel camper for my buddy sometime soon.
Y&R0864 is offline
post #4 of 37 Old 07-21-2014, 11:28 PM
Drivin the 6.mOney pit
armyguy209's Avatar
Feedback Score: 6 reviews
Truck in my Sig has an 8" lift with 37's. I bumped up the stock gearing from 3.73 to 4.30's. Made a big difference off the line and up hills. I pull a 7-8k lb boat loaded. That was with the 6.0 of course and it pulled like a raped ape when it wasn't blown up.
Dan's baby
2006 F250 CCSB Lariat 4x4 with 2007 CR 5.9 Cummins/built Allison swap and other goodies-sold
2015 F350 CCSB 4x4 Lariat Ultimate in Black tuxedo metallic
US ARMY VET
Operation Iraqi Freedom III (1 YR served in the good ol' sandbox)
armyguy209 is offline
post #5 of 37 Old 07-22-2014, 03:44 AM
NO way would I move a 5er with what you have. Even "IF" you could back up under the rig it will be extremely nose high You to level it out you'd have to have the hitch at it's lowest setting and the gap between the top of your bed and tailgate would be very small. You stand a very good risk of damaging your buddy's trailer and your truck. Depending on the weight of the 5er and height of the nose on the front of the rig your truck will struggle...especially if there are any hills to speak of.
There was a fella down here in S. Florida that didn't have as much lift and smaller tires that had to remove everything to head back west.
You have to decide what you want... When you lift a truck and install larger tires you put a lot of strain on your axles, bearings, brakes, ujoints, transmission, engine...etc. Don't get me wrong. I like the look of a lifted truck, but lose some of the utility and intended purpose of what it was intended for while gaining some capabilities.
The amount of power you lose through gearing, I'd out pull you with my stock 08 6.7 cummins even if you had a higher output ford setup.
Dougstdig is offline
post #6 of 37 Old 07-22-2014, 04:33 AM Thread Starter
Y&R0864's Avatar
Well the regearing is inevitable. But just wanting to know if I will need anything for the electronic side of things or if that will all just work fine?
And I guess I'll just keep using the old 6 speed cummins for towing.
Y&R0864 is offline
post #7 of 37 Old 07-22-2014, 07:27 PM
DeuceFifty's Avatar
6.4 liter here. Had 37's with 3.73s hooked up 9k BBQ trailer. Couldn't pull faster than 55. Kept looking for gear and got hot. Put 4.30s in a month ago. All I can say is wow. So much more power. Sucks fuel unloaded at70+ moth! but so much more fun to drive. No tunes.
2008 F-250 XLT 4x4 CC
6.4L Job 1
6" PC Stage 1 Lift
20x10 Mazzi Hulks
37x13.50 Toyo MTs
Lightforce 240RDLs
Piaa 240 smrs
Traction bars
Pmf drag link and track bar
PC stabilizer
4.30s
Detroit truetrac rear
Mag hytec rear
Nfab PreRunner
DeuceFifty is offline
post #8 of 37 Old 07-22-2014, 07:45 PM
ZMANN's Avatar
Quoted: 1472 Post(s)
the rear end VSS (speed sensor ) reads after the gears so it only reads the axle shaft RPM's and won't read off with the gear swap
We Miss you Ronnie
ZMANN is online now
post #9 of 37 Old 07-22-2014, 07:46 PM
ZMANN's Avatar
Deuce 50 what did your gears run$$
We Miss you Ronnie
ZMANN is online now
post #10 of 37 Old 07-22-2014, 08:39 PM
DeuceFifty's Avatar
That's right. If you have the hypertech inline behind dash calibrator you just change for tires, don't mess with gearing ( I learned that the frustrating way).
For my gears- let me think 1500 for 4.30s, master install kit, lube,detroit, install and mag hytec diff cover. That's just the rear axle too. I haven't done front axle yet. It took the tech about 3 days to get the setup right. I did it at 4wp in Memphis.mthe tech there is extremely particular and wouldn't let it go unless it was just right. Not sure about the 6.7s but I think the axle is the same as the 6.4 and it's a "bastard gear" or something like that because the parts are interchangeable so he went with the 10.25 internals or something along those lines to build up the guts.
