Question about 2014-15 Powerstroke Repairs? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-18-2014, 08:52 AM Thread Starter
Hey, I know I'm new to this forum but I am just seeking help on the power stoke model trucks.
Im in the market to trade up from a 1/2 ton to either the 3/4 or 1 ton trucks. I have owned my current truck for about 8 years. If i knew some of the problems before hand with the f150 i would of hesitated to buy it. I am wanting to know if you have to work on the rear of the motor of a 2014-15 models of the power stroke, do you still have to take the whole cab off the frame to do work to it. This is just a concern i have for the future once the warranty runs out. I would hate to have to spend a few thousand to change a 100 dollar part. If anyone knows this answer and can spare some advice that would be greatly appreciated.
I don't wanna spend 55k on a new truck just to spend more later because Ford couldn't find a better way to remove the motor or work on it, if any problems do happen.
I came here as the Ford dealership won't or can't give me a truthful answer on my question.
Thanks
horel is offline
post #2 of 11 Old 07-18-2014, 11:16 AM
Iowa 73's Avatar
Go to the lot, open the hood, look at the engine. Self evident.
The current generation Powerstroke is not as problematic as the 6.0, but there is a chance at some point the cab will need to come off.
2013 F-350 SRW, 4x4, 6.7L, 6R140, 3.55's TRADED for a 2013 Ram 3500 SRW, 6.7L
2000 F-250, 4x4 , 7.3L, 4R100, 3.73's
1997 F-250, 4x4 , 7.3L, E4OD, 4.10's, 5.5" lift, D60, 37's, Baby Swamps, Swamps tunes, 1.0 housing and EBPV delete pedestal
1996 F-250, 4x4 , 7.3L, ZF47, 4.10's
1992 F-350, 4x4 Dually Dump, 7.3L, E4OD, 4.10's
Iowa 73 is offline
post #3 of 11 Old 07-18-2014, 04:18 PM
tibadoe's Avatar
There is a chance of having to pull the cab for engine work depending on what is wrong. There is one in our local dealership that has the cab & front end pulled. I try not to look at it when I stop by to see the salesman.
Joe
tibadoe is offline
post #4 of 11 Old 07-18-2014, 09:01 PM
RJC2's Avatar
Quoted: 366 Post(s)
You know, I had the same thoughts before I bought my truck, I called a friend who is a Tech at the local dealership about the practicality of removing the cab for major service. He told me it wasn't a big deal for him as he so good at it that he can have them off in a little over an hour. He said that it makes working on them so much nicer as he doesn't have to worry about dropping a wrench or a heavy part on the customers fender. The cab is 7 feet up and out of the way while he works on it. Then the rest of the repair goes so much faster as he isn't climbing on a platform and leaning in the engine bay. He said that on major repairs the job actually ends up getting done quicker in the end and his back feels much better at the end of the day.
I think it just sounds bad to me when you say that you have to remove the cab.
Anyway, I wanted to say
2017 F350 CCSB King Ranch Ultimate 6.7
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler, CTS Insight monitor,
RJC2 is offline
post #5 of 11 Old 07-19-2014, 04:27 AM
Quoted: 279 Post(s)
I agree with rjc2.. sounds bad but if you think about it, itnis some bolts and unplugging some harnesses etc. It can be done in 60-90 minutes which is far better then digging into a motor to get down to a part. I rather have the cab off then 50% of the motor on a work bench.
15 6.7 F350 CCSB 4x4 Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2, Dieselsite fuel filter, DeeZee tailgate assist, Hellwig Rear Sway bar, Bilstein 5100s
**Support the Online Vendors!!! Want your best price, buy from Scott Pratt!! Get your truck in 3-4 weeks, order to delivered!!
blwnsmoke is offline
post #6 of 11 Old 07-19-2014, 04:53 AM
Ontario Trucker's Avatar
I trust the techs at Ford completely, they've been lifting cabs off for 10 yrs now for different reasons ........ I agree with RJ
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
post #7 of 11 Old 07-19-2014, 08:10 PM
Actually ford has made it easier than ever to remove the cabs on the superdutys. every year it gets easier to do, and in the 6.7s its the easiest yet, and can easily be done in an hour. However with the amount of stuff under the hood, it becomes more necessary on repairs, but still only occurs on major engine work. most or all of the repairs can be done with the cab on, but its just a lot easier to pull it. Don't be to worried, duramax trucks, especially lately have been getting cabs pulled to on the same premise. its just easier to deal with. Only ones that don't are cummins, and mainly because its an inline 6.
1995 F-350 Dually, 4x4, auto, 4" straight pipe, aFe intake, DP tuner. 357k miles still original motor!
2004.5 2500 cummins 4x4, auto, 5" DE, K&N, smarty s06 POD. (not that anyone on this forum cares)
diesel_forever is offline
post #8 of 11 Old 07-19-2014, 09:21 PM
This is nice and all, but the actual time it takes vs. the billable hours charged are another thing. I was charged 3 hours labor for a crank position sensor that took 20 minutes to change. They charge what ever is posted on their system... It may be good for the mechanic...but the consumer will bite it in the end...
Dougstdig is offline
post #9 of 11 Old 07-20-2014, 12:53 AM Thread Starter
For everyone that chimed in thank you.
horel is offline
post #10 of 11 Old 07-20-2014, 04:34 AM
We're here to try n make sense of it all, it isn't always fair........
