Let's see your lifted plow set ups! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-16-2014, 05:09 PM Thread Starter
Looking to go with a carli 2.0 performance lift, and western wideout/blizzard 8611lp/fisher XLS plow.
Anyone running a lifted set up and have pictures??
2012 6.7L F-350 4x4, XLT EC/LB SRW
Done april/2014-
Used SPARTAN dashdaq-XL, AFE intake, and 4" straight pipe exhaust (DPF deleted)...
Mods to come:
EGR delete
36x15.50R20's with -44 offset rims and a lift to accommodate!
Located in Ontario!
x-SYOTOS-x is offline
post #2 of 7 Old 07-17-2014, 12:57 PM
OCVeloMan's Avatar
Quoted: 158 Post(s)
Garage
Just popping in to tell you to go with the BackCountry, more travel, same performance, $300 less. Better in every regard... We have plenty of people that plow with our kits, most are around 1,000-pounds and drop the front 1-1.5" when installed then it'll pop right back up when you drop the plow.
OCVeloMan is offline
The Following User Says Thank You to OCVeloMan For This Useful Post:
x-SYOTOS-x (07-17-2014)
post #3 of 7 Old 07-17-2014, 02:49 PM Thread Starter
Does the back country have full replacement springs included aswell?
Thanks for your advice! Very helpful!!
Done april/2014-
Mods to come:
EGR delete
Located in Ontario!
post #4 of 7 Old 07-17-2014, 03:24 PM
OCVeloMan's Avatar
Quoted: 158 Post(s)
Garage
It comes with the add-a-pack but the Full leafs are a $445 upgrade to the kit and a HUGE ride quality increase.
post #5 of 7 Old 07-17-2014, 03:39 PM Thread Starter
That's pretty cheap.
I'm looking to add airbags to hold the weight of the ballasts, so new leafs would be smart anyway!
Thanks for your help!
Done april/2014-
Mods to come:
EGR delete
Located in Ontario!
post #6 of 7 Old 07-22-2014, 10:23 AM
Skyd Ram's Avatar
Quoted: 131 Post(s)
Assuming that you are talking about the 4.5" system I would recommend the Carli bags as they don't negate a lot of the ride improvement of the full leafs.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #7 of 7 Old 07-22-2014, 10:32 AM
IronCobra's Avatar
Quoted: 9 Post(s)
Down here you don't use a snow plow, you strap a huge sponge (4'x8'x2.5') to the front and soak up the humidity. Then you drive over it 25 times to drain it out (hoping not to flood your street).
2016 F450 Platinum FX4 CC LWB
2016 Chaparral 360IBL Fifth Wheel: 15,500lbs
GONE - 2011 F250 FX4 6.7L Lariat Ultimate
IronCobra is offline
Tags
lift , plow
