Evaporator Mold?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-15-2014, 05:55 AM Thread Starter
Evaporator Mold??
My truck has recently developed a musky smell in the A/C. I think this is prolly mold on the evaporator core?
My question is, , , can I fix this issue myself or is this something for the dealership? Has anyone had this condition and been able to home remedy the problem. How did you do it?
I live in the desert so humidity is very low but I know the evaporator drain works as we have been having the monsoons lately and I see puddles under the truck when I stop.
Thanks
mowdoc
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #2 of 4 Old 07-15-2014, 06:05 AM
ZMANN's Avatar
Quoted: 1464 Post(s)
I have seen a diy kit
We Miss you Ronnie
ZMANN is offline
post #3 of 4 Old 07-15-2014, 06:52 AM
RJC2's Avatar
Quoted: 311 Post(s)
I had the same problem on one of my past trucks. I tried to fix it myself to no avail. I ended up going to the dealership who not only cleaned it with a foam that filled the HVAC system, but also put an add on unit on the truck (under warranty) that caused the blower fan to run for 2 minutes after shut down drying up the evaporator. It worked well and I never had a problem after that. I wish I kept the part numbers for the unit but the dealer should know what it is if you elect to go that route.
FWIW, before the repair was finally done, they told me not to use "Max A/C" as that was part of the problem.
2017 F350 CCSB King Ranch Ultimate 6.7
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler, CTS Insight monitor,
RJC2 is offline
post #4 of 4 Old 07-15-2014, 12:46 PM
tibadoe's Avatar
It might help, before you shut down the truck, is to cut the A/C off and let the fan run till the air flow is warm again. Usually only takes 30 - 60 seconds. Works for me and no molded up evaporator or smell. If it's already molded up most likely will have to have it cleaned first.
Joe
tibadoe is offline
