Anyone elses AC leak water on passenger floor mat? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-14-2014, 07:57 PM Thread Starter
Quoted: 2 Post(s)
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 13 Old 07-14-2014, 10:30 PM
jvd2999's Avatar
Mine leaks water into the ground under the passenger side. I did have a similar problem with the 09 F150 I traded in for my '12 F250. The condenser drain plumbing wasn't right is what they kept telling me. Several trips to and from the dealer and I gave up. Pulled up the carpet, dried it up, and the traded it in for what I really wanted. I hope the dealer can fix yours better than mine
jvd2999 is offline
post #3 of 13 Old 07-15-2014, 03:52 AM
Quoted: 71 Post(s)
Crawl under the truck on passenger side and check the AC drain tube that comes through the truck floor to insure it is open. My old 96 use to stick shut at times. I would open it and it would be ok for a 6-9 months and then stick again.
If it is open, see if you can check the cab to see if drain tube is attached to the ac/heater box inside the truck.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #4 of 13 Old 07-15-2014, 05:59 AM Thread Starter
Quoted: 2 Post(s)
Mine seems more like condensation.
I do get a puddle under the passengers side tire when idling.
wreedPS is offline
post #5 of 13 Old 07-15-2014, 06:53 AM
wreedPS:
I have a fairly new 2014 Ford SD, Lariat PSD 6.7 with about 3,800 miles on it now and noticed some water droplets on the passenger floor mat last week.
It was a VERY hot day with real high humidity so that may have caused it.
But, I will check the tube the members here have mentioned and see if there is something obstructing it.
John_P
2014 Ford F-250 Super Duty, 4WD, Crew Cab, Lariat Ultimate, FX4 6.7 "Scorpion" Turbo Diesel
John_P is offline
post #6 of 13 Old 07-15-2014, 07:37 AM Thread Starter
Quoted: 2 Post(s)
hot day and high humidity with me too, I am in Houston!
wreedPS is offline
post #7 of 13 Old 07-15-2014, 09:24 AM
automoto's Avatar
Quoted: 11 Post(s)
hot and humid day day down in NC and the interior pieces in the passenger foot well had condensation on them, and the truck usually has a puddle under it from the ac too. I havnt seen it do this again, just figured it was because it was so damn hot and humid
2014 F350 CCSB 6.7 Platinum
automoto is offline
post #8 of 13 Old 07-15-2014, 10:07 AM
garyfulton's Avatar
I think thats your problem wright there.
garyfulton is offline
post #9 of 13 Old 07-17-2014, 08:29 PM Thread Starter
Quoted: 2 Post(s)
Do these trucks have a rubber drip tube for the AC? My truck just has a metal pipe sticking out the firewall.
wreedPS is offline
post #10 of 13 Old 07-18-2014, 07:58 AM
daystrom's Avatar
Quoted: 8 Post(s)
I don't think it is a drain problem. My truck does the same thing and it is condensation from the air box being so cold. Like a cold glass on a hot day.
2012 F-350 Lariat 4x4 6.7 PSD
Platinum metallic / adobe accent
"Sir Topham Hatt thinks I need to learn. He is mistaken. We Diesels don't need to learn, we know everything. We come to a yard and improve it. We are revolutionary!"
daystrom is offline
