Trailer Sway Control - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 22 Old 07-11-2014, 07:03 PM Thread Starter
fordtrix's Avatar
I saw this mentioned in a couple threads regarding mileage, so I did some investigation. I heard that it increases mileage to turn it off. I've noticed a fuel drop the last few months (could be a number of things) so I went and turned it off. Did a short trip and it did surprisingly better on mpg.
Now, I noticed that every time I turn the truck off, and turn it back on, the trailer sway control is automatically on. Does this mean that I have to shut it off each time?
Does it really increase mileage or am I crazy? My short "trip" was just about 15 miles of highway where I reset it (my gauge is usually within .5mpg accuracy) and it did the best it had done in months.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #2 of 22 Old 07-12-2014, 05:16 AM
Now seriously do you really believe this was a fair assessment of having it turned off to get a substantial improvement? Did you drive this same exact route with the same weather conditions with it turned on to verify? GEEEEZZZZZ
And yes it resets every time the truck is turned off. This is a safety feature so it automatically resets.
2014 Blue Jeans blue F250 CCSB 6.7 Lariat w/Lariat ultimate pkg, chrome pkg, 3.31 E-locker FX-4 pkg, rustproofed/undercoated, Access Limited tonneau, Weathertech wheel well liners, Weathertech mudflaps, Linex matching blue bed liner, Enduraplas transfer tank, Air Lift 5000 airbags.
schrod is offline
The Following User Says Thank You to schrod For This Useful Post:
Iowa 73 (07-12-2014)
post #3 of 22 Old 07-12-2014, 05:22 AM
Ontario Trucker's Avatar
What Schrod said
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
post #4 of 22 Old 07-12-2014, 05:42 AM
Iowa 73's Avatar
Placebo effect.
rossmelvin and schrod like this.
2013 F-350 SRW, 4x4, 6.7L, 6R140, 3.55's TRADED for a 2013 Ram 3500 SRW, 6.7L
2000 F-250, 4x4 , 7.3L, 4R100, 3.73's
1997 F-250, 4x4 , 7.3L, E4OD, 4.10's, 5.5" lift, D60, 37's, Baby Swamps, Swamps tunes, 1.0 housing and EBPV delete pedestal
1996 F-250, 4x4 , 7.3L, ZF47, 4.10's
1992 F-350, 4x4 Dually Dump, 7.3L, E4OD, 4.10's
Iowa 73 is offline
The Following User Says Thank You to Iowa 73 For This Useful Post:
rossmelvin (07-12-2014)
post #5 of 22 Old 07-12-2014, 09:08 AM Thread Starter
fordtrix's Avatar
Whoah, you mean all of those play factors in mileage? How about type of driving? Like... If I floor it everywhere I go, will it get the same mileage as if I drive like the asian grandma that lives down the street? Please.. I want to learn..
/sarcasm
I brought it up because I saw it mentioned in two separate threads for making a difference.
I have over 40,000 miles on my 2013 F250 with the majority of them being highway. I have a "pretty" good idea of exactly what mileage I will get in all of my typical routes that I drive (I spent 8 months driving 35 miles each way to the gym and 15 miles each way to work) in the exact same route. Both were all highway with varying speeds of 55-70. So, yeah, I typically know about what my mileage is.
The reason I am bringing it up, is because it has significantly dropped over the last 2 months. To the tune of about 2-3mpg. I did a 400 mile round trip last week, and while at a flat 65-73 mph I'd usually get about 16, I got about 14, and it's been like that for a while. I am driving over 1000 miles tomorrow/Monday, however due to my trailer I obviously won't get a good estimate.
Right now I'm trying to explore different options, although turning something off which has always been on (trailer sway control) obviously shouldn't be the indication of while my mileage has changed so much. I have also noticed more re-gen's (seemingly) which is another thing I will need to have looked at, and that I obviously consider if that is the case.
I didn't feel the need to post all of this information in my original post as I would assume that it's understood here that most people understand gas mileage. Not to mention, my post was about trailer sway control and it effecting mileage and turning it off permanently........
My point being is that if I reset my mpg gauge and got 19.5 mpg on a 15 mile trip last night at highway speeds, it was better than anything even remotely close that I've been able to achieve for a very very long time.
fordtrix is offline
post #6 of 22 Old 07-12-2014, 11:11 AM
/sarcasm
I didn't feel the need to post all of this information in my original post as I would assume that it's understood here that most people understand mileage. Not to mention, my post was about trailer sway control and it effecting mileage and turning it off permanently........
Where you have been buying your diesel fuel and whether or not you are using a cetane booster are also very big factors. Also consider you get gas mileage with a gas engine and fuel mileage with a diesel..........
schrod is offline
post #7 of 22 Old 07-12-2014, 01:36 PM Thread Starter
fordtrix's Avatar
Neither of those have changed. Either way, the topic here is trailer sway control. Apparently you dont know anything about that, though.
fordtrix is offline
post #8 of 22 Old 07-12-2014, 01:41 PM
POWERCHOKER
Dantron's Avatar
How is Trailer Sway Control supposed to work? Does it turn on even when you're not pulling a trailer?
Dantron is offline
post #9 of 22 Old 07-12-2014, 01:43 PM Thread Starter
fordtrix's Avatar
Yes. You have to turn it on each time manually. From what ive found is it gently applies breaks when the truck sways to prevent the swaying. In turn effecting mileage.
I don't know much about it though which is why I started the thread.
fordtrix is offline
post #10 of 22 Old 07-12-2014, 01:48 PM
POWERCHOKER
Dantron's Avatar
Turn it on manually or turn it off manually?
Dantron is offline
