Let's See Your Cab Lights!!! - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 20 Old 07-09-2014, 09:46 AM Thread Starter
POWERCHOKER
Dantron's Avatar
I'm going to be installing cab lights soon and I want to get a feel on how everyone has their lights positioned... Thanks!
Dantron is offline
post #2 of 20 Old 07-09-2014, 09:58 AM
Coffaro's Avatar
I was just going to order a set and put them in the factory position.
Coffaro is offline
post #3 of 20 Old 07-09-2014, 10:26 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Hmm..
I've been contemplating whether I should align them front to back, kind of like a mohawk.
seadog likes this.
Dantron is offline
post #4 of 20 Old 07-09-2014, 12:15 PM
automoto's Avatar
Quoted: 13 Post(s)
i have the recon smoked lenses and put in led amber lights. truck came factory with cab light option. i think they make the truck look better, but to each their own
2014 F350 CCSB 6.7 Platinum
automoto is offline
post #5 of 20 Old 07-09-2014, 12:25 PM
RTFU!
GridLine's Avatar
Quoted: 4 Post(s)
Originally Posted by Dantron View Post
Hmm..
Dantron, I regularly find myself laughing out loud to your posts.
When I bought my truck they didn't come with roof clearance lights so, I had them installed by the dealer. Here's a couple pics.
IMG_1379_zps8a175a4a.jpg Photo by dcampisano | Photobucket
IMG_1380_zps97b1968d.jpg Photo by dcampisano | Photobucket
Dantron likes this.
2016 F350 KR
Thanks 8LUGTRUCKGEAR!
-Dave
GridLine is offline
post #6 of 20 Old 07-09-2014, 05:35 PM
seadog's Avatar
Cablights
Cablights from the factory(and the rest of them too)
Dantron likes this.
[/SIGPIC]Seadog
2014 C/C Lariat Ultimate
Short Box,Stock
seadog is offline
post #7 of 20 Old 07-09-2014, 07:23 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Dantron was asking me about my atomic LED cab lights and figured I'd post for everyone to see in case anyone was interested. I ordered the clear lens ford atomic led kit from strobes n more. ill post a link a little further down. after doing my dads platinum first i decided to wire the lights up my self. the atomic lights use the factory plug but for the strobes there is a signal wire that goes from the atomic led flasher relay to each one of the lights. the relay has to be mounted down by the headlight switch behind the dash for room so running a wire from the relay to each light got messy but doable. for doing my 6.4 i decided its cleaner looking to use the atomic led harness which has the wires already shrink wrapped and organized for a clean and hassle free install. definitely worth the extra money. they are very easy to install. they are a dead copy of the oem cab light housing and are very good quality. ive installed a few sets and everyone loves them. ive seen a few people wire them up where the cab lights stay on and strobe but they arent installed right. if you wire them up like the directions say, if your running lights are on and you flip the strobes on the cab lights should turn completely off and strobe. you will see in my video. i have the running lights on and the cab lights still strobe and when you turn strobes off the cab lights go back to normal operation. i left mine on the random flash pattern but there is a wire you can hook up to change pattern. you hook up the wire to a switch and the other end to a 12v+ source. flip the switch on and off and it will cycle to the next flash pattern. it will explain all this in the instructions. i left mine on random for the most noticeable caution lights i could get.
Dantron i know you mentioned wanting to make a mohawk out of the lights but with your truck being lifted they prolly wouldnt be very noticeable. plus the cab lights and a rounded shape to them to seal to the roof in the front since they mount where the cab is starting to roll down. so if you tried to mount them on the flat spot of the roof they may not seal right. id go with the factory measurements so the wiring harness works and the truck looks clean and not hacked up.
here is a link to the cab light kit. each light has like 50 leds shining in all directions so they arent like the cheap recon lights(hence the heavy price tag)
Atomice LED Custom LED Running Lights
here is a link to the ford harness, its $50 but i googled the part number and found one a good bit cheaper, just an FYI
Ford Wiring Harness for Ford Trucks ? Atomic LED - Custom LED lighting for trucks
also i just did another cab light install for my neighbor. he found a 2014 with everything he wanted except cab lights so i installed them for him this past weekend. using oem harness and oem lights. heres some pics just for you guys to see the drilling process and before and after look wise. i think the trucks look naked without them lol. i use blue painters tape to mark the holes and so they shavings dont scratch the paint
5B328017-5E98-466F-8419-0B5F944173AA_zpsfwsyjev9.jpg Photo by travis_photoalbum | Photobucket
Here's the video of my lights
Dantron likes this.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
The Following User Says Thank You to travisH3 For This Useful Post:
Dantron (07-09-2014)
post #8 of 20 Old 07-09-2014, 07:24 PM
IronCobra's Avatar
Quoted: 9 Post(s)
I love my cab lights. Been through several touch-less and brush car washes since installing mine and they have not leaked one drop. They are really bright and you can easily replace the incandescent bulbs with LED bulbs if you prefer. Also, you can tint the lenses smoked if you want using appropriate paint. Plus, they require much much smaller holes AND you only have to run 1 wire for power to each light as opposed to a power and ground wire. The lights ground to the vehicle through the hole you make.
2016 F450 Platinum FX4 CC LWB
2016 Chaparral 360IBL Fifth Wheel: 15,500lbs
GONE - 2011 F250 FX4 6.7L Lariat Ultimate
IronCobra is offline
post #9 of 20 Old 07-09-2014, 08:32 PM Thread Starter
POWERCHOKER
Dantron's Avatar
Im waiting on the video to upload to youtube. once its up Ill post the link.
Thanks man! I've had the Atomic LED cab lights in my possession for a couple weeks now and I'm getting close to the install. I also purchased the wiring harness from Atomic. It'll be good to have a rundown on how the flash system works before dropping the headliner and doing the wiring. Looking forward to the video!
By the way, I'm still kidding about the mohawk idea. I know you've heard me mention it before. I was really hoping for someone to tell me how stupid it would be look. I want to do something unique with the cab light positions, but a mohawk is plain silly. I'm thinking about going slightly wider with the outer cab lights than most people. Would that cause problems?
Dantron is offline
post #10 of 20 Old 07-09-2014, 08:43 PM Thread Starter
POWERCHOKER
Dantron's Avatar
I wish these Atomic cab lights only required 1 hole. I'll end up having to drill 15 holes for these. The flashers will be fun to use though. It's pretty much the only reason I went with them.
Dantron is offline
