2013 F250 w/ Snow Plow Pkg - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-07-2014, 07:06 AM Thread Starter
I have a 13 F250 4x4 FX4. I bought it and it had the snow plow package on it. From what I understand the difference is stiffer springs in the front.
My truck seems to be a touch lower in the rear than the front and it gets on my nerves.
Would replacing the springs with the stock springs be worth it? I guess it might ride a little better possibly.
If I did that would I have to have an alignment done?
Or would I be better off putting like a 1" block in the rear?
Also thinking about changing the stock shocks out. Not sure which ones to go with though. Reading on here there seems to be mixed feelings about all of them.
Thanks
johnboy27 is offline
post #2 of 3 Old 07-07-2014, 08:26 AM
mor4wd's Avatar
If you want to improve your ride quality a bit then I'd replace those front springs with the standard springs. You could also put blocks from an F350 on the rear and that'd lift it up a little bit.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 3 Old 07-07-2014, 09:46 AM
6.0f250firstcar's Avatar
^^^^this
Ryan
6.0f250firstcar is offline
