Upgrading shocks on 12 F350 - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-06-2014, 07:22 PM Thread Starter
Duffie112's Avatar
Send a message via AIM to Duffie112
Hey guys I have the fx4 package and I believe they are rancho shocks. I hear there junk for ride quality? What shocks are you guys upgrading to to make the ride nicer? Thanks guys
Sent from AutoGuide.com App
Cory Duffie
2012 F-350 CC 6.7L
H&S
Incubus
AFE
Flo Pro
Duffie112 is offline
post #2 of 13 Old 07-06-2014, 07:50 PM
RJC2's Avatar
Quoted: 350 Post(s)
I'd like to know the same thing...
2017 F350 CCSB King Ranch Ultimate 6.7
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler, CTS Insight monitor,
RJC2 is offline
post #3 of 13 Old 07-06-2014, 10:51 PM
I had Bilstein on my 2500 and changed them out for KYB Mono Max. I just happened to be driving here in S. Florida and stumbled across a place I'd seen on the net. ShockWarehouse.com. They recommended the Mono Max to me and I'm really glad they did. They do a great job. I took the liberty to look at their site for you...
Front...Part # 565121...$71.06 each with free shipping
Rear...Part # 565124...$84.43 each with free shipping
Purchase set of 4 for 310.43...again free shipping.
High pressure gas design (280psi)
Monotube design
Hardened chrome 1/2 piston rod
Seamless body cylinders and eye rings
Floating piston
Self-sealing packing
Velocity-sensitive valving
Large 46mm bore and piston
"KYB MonoMax performance gas shocks. For hot trucks, sporty SUVs, and 4WDs. These shocks are engineered and designed to deliver performance and strength regular shocks don't have. These shocks have a vehicle specific valving for severe duty and handling. They help reduce squat under acceleration, helps eliminate braking nose dive, and helps control roll and pitch. These are the KYB Gasajust on steroids! Bigger and better. "
cheers
Dougstdig is offline
post #4 of 13 Old 07-07-2014, 03:46 AM Thread Starter
Duffie112's Avatar
Awesome thank you Dougstdig!
Cory Duffie
2012 F-350 CC 6.7L
H&S
Incubus
AFE
Flo Pro
post #5 of 13 Old 07-07-2014, 04:00 AM
Iowa 73's Avatar
I put Rancho RS9000 on mine. Much better than stock. There is a thread on here already about shocks.
2013 F-350 SRW, 4x4, 6.7L, 6R140, 3.55's TRADED for a 2013 Ram 3500 SRW, 6.7L
2000 F-250, 4x4 , 7.3L, 4R100, 3.73's
1997 F-250, 4x4 , 7.3L, E4OD, 4.10's, 5.5" lift, D60, 37's, Baby Swamps, Swamps tunes, 1.0 housing and EBPV delete pedestal
1996 F-250, 4x4 , 7.3L, ZF47, 4.10's
1992 F-350, 4x4 Dually Dump, 7.3L, E4OD, 4.10's
Iowa 73 is offline
post #6 of 13 Old 07-07-2014, 07:18 AM
Quoted: 11 Post(s)
I replaced the "Rancho" shocks on my 2013 F250 FX4 with Bilstein 5100's. I made the change when the truck only had a few thousand miles on them. The OEM's definitely do not work great and I trust the Bilsteins to last a long time. However, the new shocks didn't suddenly transform the ride into a cushy smooth drive. The ride was slightly improved but you really have to pay attention to it to notice. And I race cars as a hobby so I think I can pick up on suspension changes a lot better than the average person.
If your shocks are toast, then I'm sure the Bilstein's will improve the ride (any working shock would at that point). And maybe other shocks will work better for improving ride quality. I'm still happy I made the change because I didn't expect the OEM shocks to last long and Bilstein makes a durable shock.
Drewtk is offline
post #7 of 13 Old 07-07-2014, 07:49 AM
Quoted: 2 Post(s)
Agree 100%. I have 5100s on mine and my stock shocks were shot when I replaced mine. The truck doesn't ride any different really. It rebounds better when you hit a pot hole or go over rail road tracks but it will not turn it into a Cadillac.
Stock for now.
Bluwaterbrew84 is offline
post #8 of 13 Old 07-07-2014, 08:07 AM
extrmach's Avatar
I don't have KYB's anymore but they are made here in Indiana up the road from me.They look like a great shock for a great price.
2014 F350 SRW LB King Ranch FX4, 6.7L "Scorpion" Diesel, 2 Tone Paint Pkg
Options: Moonroof, 5th Wheel Trailer Tow Pkg, 11,400 GWVR Pkg, 275/65R20 Michelin LTX A/T 2 Tires, Rapid-Heat Supplemental Cab Heater, Engine Block Heater, Upfitter Switches, Tailgate Step
Adds: Ford Wheel Well Liners, Weathertech Floor Liners, Weathertech No-Drill Mud Flaps
extrmach is offline
post #9 of 13 Old 07-07-2014, 10:04 AM
id go with fox
azdbllung is offline
post #10 of 13 Old 07-07-2014, 10:18 AM
POWERCHOKER
Dantron's Avatar
The real way to improve ride quality is with King's dual coil-over shocks all around and a Rigid light bar mounted on the roof. No exceptions...
Dantron is offline
