First oil change tomorrow, what to do? - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 39 Old 07-02-2014, 03:56 PM Thread Starter
I hate to sound like newb, but this is both my first new and first diesel truck. I want to do everything right, even though I have changed oil hundreds of times on different vehicles, I dont want to overlook anything.
Oil:
What kind of Rotella oil should I use? Just regular full synthetic? And what viscosity? (probably printed on the oil cap, but Im too lazy to run outside to pop the hood now). And how much oil does the 6.7 take?
Filter:
I am probably just going to use a regular Carquest Redline oil filter. Any objections to that?
Misc:
Anything else I should do or check out at this 5k mark? Tires look good all round, recently put oversized on so no need for a rotation yet.
Thanks in advance. Just want to make sure I am maintaining the best possible maintenance for the truck.
ak22801 is offline
post #2 of 39 Old 07-02-2014, 04:39 PM
99powerstroke62's Avatar
Quoted: 56 Post(s)
I run Rotella T6. Takes 13 quarts.
I would use motorcraft filter. Just my .02
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #3 of 39 Old 07-02-2014, 04:48 PM
POWERCHOKER
Dantron's Avatar
I use 5w-40 synthetic, which is Rotella T6. However, I've heard of people also having success with 10w-30. You'll need 13 quarts, so buy (4) 1 gallon jugs and you should have 1 quart leftover. You may want to check if the air filter needs replacement.
Dantron is offline
post #4 of 39 Old 07-02-2014, 04:54 PM
Quoted: 56 Post(s)
I believe it's 3 one gallon jugs and one quart.
Otherwise you'll have 3 extra quarts.
Tyler
The Following User Says Thank You to 99powerstroke62 For This Useful Post:
texaslimeaide (07-02-2014)
post #5 of 39 Old 07-02-2014, 05:03 PM
POWERCHOKER
Dantron's Avatar
Whoops! You're right. Only use 1 quart out of the 4th gallon and pour the rest down the sink or in the gutter. My bad..
Dantron is offline
post #6 of 39 Old 07-02-2014, 05:50 PM
texaslimeaide's Avatar
I second the motorcraft filter. Don't use cheap filters on an expensive truck.
13' CCSB FX4 6.7, 17"MB wheels, Cooper oversized all terrains, Amsoil 15w40 Diesel/Marine oil with Ea Oil Filter.
2013 6.7 Powerstroke F250 XLT Crew Cab 4X4 First Owner. Amsoil OE 15W40 Diesel Motor Oil. MB Wheels and Cooper 34.5" x 12" tires.
SOLD!! 2006 F250 Lariat Crew Cab 4x2 88k miles, 4" Diamond Eye Turbo Back Exhaust, Amsoil 15W40 Synthetic Heavy Duty Diesel and Marine Motor Oil, Ea Amsoil 15k oil filter, Oil Charge Systems Amsoil Bypass Filter, SCT TSX (no custom tunes yet), Sinister Coolant Filter Kit, Zoodad Mod, Custom Diesel EGR Cooler Delete.
texaslimeaide is offline
post #7 of 39 Old 07-02-2014, 06:21 PM
Quoted: 274 Post(s)
DO NOT use anything but Motorcraft filters on these trucks!!!
RJC2 likes this.
15 6.7 F350 CCSB 4x4 Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2, Dieselsite fuel filter, DeeZee tailgate assist, Hellwig Rear Sway bar, Bilstein 5100s
**Support the Online Vendors!!! Want your best price, buy from Scott Pratt!! Get your truck in 3-4 weeks, order to delivered!!
blwnsmoke is offline
post #8 of 39 Old 07-02-2014, 06:52 PM
RJC2's Avatar
Quoted: 352 Post(s)
There was a test done some years ago on Oil Filters. I don't remember where I saw it now. Most of the Non Factory brand filters (like Fram) were equal to having no filter at all. Motorcraft filters rated near the top of the list, with Baldwin filters being the best over all.
You can't go wrong with Motorcraft, especially for the price.
Regarding oil, you might want to consider going with at least a synthetic blend as that is what Ford puts in them from the factory. I also use a additive from Ford called XL-17. Some on this site say it has stopped the dreaded "typewriter noise" that the 6.7 sometimes gets after the oil is changed. I use it as a preventative measure.
I have my oil changed at the Ford dealership. While I admit there's something satisfying about doing it yourself, they [the Ford dealer] does it for about the same price that I can do it myself. You also get the benefit of having the oil changes documented in the Ford computer system so that if there's ever a warranty issue with the engine, Ford can't argue that you didn't change it properly, or within the correct interval. Also, if there any updates or a reflash needed, they do it then as well. They also top off my DEF and only charge for the amount used, and drain the fuel water separator. I change mine every 3,000 miles.
I hope this helps.
2017 F350 CCSB King Ranch Ultimate 6.7
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler, CTS Insight monitor,
RJC2 is offline
post #9 of 39 Old 07-02-2014, 06:54 PM
bigblzr94's Avatar
Quoted: 4 Post(s)
you should top of the exhaust fluid as well.
2014 F-250 Platinum Kodiak Brown (1st Ford ever, and loving it, thanks for nothing GM)
2014 Chevy "Shakearado" POS traded to Ford after 3 months
1999 GMC Suburban k2500 454 (gas hog)
1994 Chevy Blazer 2 door (dog truck)
1997 Chevy C1500 Prerunner (toy)
bigblzr94 is offline
post #10 of 39 Old 07-02-2014, 06:57 PM
Quoted: 27 Post(s)
My preferences are -
Every 3,000ish
Rotella T6 5W-40 13 quarts
5/8" wrench for the drain plug and prepare for the oil to come almost straight out of the drain hole once the plug is removed. More than one guy has figured this out the hard way.
Baldwin or Motorcraft filters
Reset the oil life reminder in the dash
Drain the water separator
Air and fuel every 12-15,000
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
