Confederate Diesel turbo problem - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-01-2014, 08:44 PM Thread Starter
I just installed a turbo kit from this company and for some reason when under a lot of boost the piping blows off of the boot. What is a simple fix to this? One of my buddies is telling me to get a bov and it will prevent this but i do not think that will help this at all. Anything will help thanks
jnitchoff is offline
post #2 of 12 Old 07-01-2014, 08:52 PM
texaslimeaide's Avatar
Have you tried cleaning the pipe and spraying hairspray on it when you slide it back in the boot? That pretty blue color looks slick as greased hog poo.
13' CCSB FX4 6.7, 17"MB wheels, Cooper oversized all terrains, Amsoil 15w40 Diesel/Marine oil with Ea Oil Filter.
2013 6.7 Powerstroke F250 XLT Crew Cab 4X4 First Owner. Amsoil OE 15W40 Diesel Motor Oil. MB Wheels and Cooper 34.5" x 12" tires.
SOLD!! 2006 F250 Lariat Crew Cab 4x2 88k miles, 4" Diamond Eye Turbo Back Exhaust, Amsoil 15W40 Synthetic Heavy Duty Diesel and Marine Motor Oil, Ea Amsoil 15k oil filter, Oil Charge Systems Amsoil Bypass Filter, SCT TSX (no custom tunes yet), Sinister Coolant Filter Kit, Zoodad Mod, Custom Diesel EGR Cooler Delete.
texaslimeaide is offline
post #3 of 12 Old 07-01-2014, 08:55 PM
c69ss396's Avatar
Your first problem was going to Confederate Diesel, they do shotty work. the issue is there is no flare/bead roll at the end to keep it from blowing off. Typical poor quality work is what they are known for...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #4 of 12 Old 07-01-2014, 08:57 PM Thread Starter
I am out of town until Monday so I'll have to try that when I get back. From my own knowledge I think sanding it a little to rough it up and using the hairspray might work
post #5 of 12 Old 07-01-2014, 08:57 PM Thread Starter
Originally Posted by c69ss396 View Post
Your first problem was going to Confederate Diesel, they do shotty work. the issue is there is no flare at the end to keep it from blowing off. Typical poor quality work is what they are known for...
Thanks for your input but do you have any suggestions how to fix this?
post #6 of 12 Old 07-01-2014, 09:03 PM
Worth a shot. You asked for cheap and roughing the surface and a thin coat of hairspray is pretty cheap haha.
post #7 of 12 Old 07-01-2014, 09:04 PM
The flare would help greatly.
post #8 of 12 Old 07-01-2014, 09:06 PM Thread Starter
Anyway I could flare it myself?
post #9 of 12 Old 07-01-2014, 09:27 PM
Quoted: 26 Post(s)
You may be able to get a muffler shop to put the hurt on it a little to get a small flare and not mess things up. You didn't say what material this was made of, but I would guess at aluminum. You may also try to get longer boots or tubes. This will lessen the amount that things can flex and push apart. Another option might be to have a bead welded around the end, but that is a little extreme.
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #10 of 12 Old 07-01-2014, 09:30 PM
^^^^^^^^^^^^^^ I second what sterling said if you want to try and fix the non flare issue. A machine shop might have a solution too.
