blew IC pipe - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-01-2014, 03:25 PM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
blew IC pipe
hey fellas,
one of our guys was driving our 2012 6.7 f450 on the highway when it blew and lost all power obviously. he said the hood looked like it popped up lol. well they loosened up the boot and tightened it back down and its fine now. but whats the best way to prevent this from happening again? remove the boot, clean it good and hair spray it? or is there an issue causing this to happen. truck has about 30k miles fyi its the boot connecting the black plastic pipe going to intercooler
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #2 of 12 Old 07-01-2014, 05:30 PM
sagebel's Avatar
Quoted: 10 Post(s)
H&S makes a metal replacement.
2012 F350 DRW King Ranch FX4
Originally Posted by nighthawk285 View Post
Pull it sideways back and forth....and don't be gentle
Originally Posted by Six0~Stroker View Post
I was just planning on running over here and whipping it out. Sent from
sagebel is offline
post #3 of 12 Old 07-01-2014, 08:04 PM
but thats usually because they actually break. Hmm…. maybe it just has a bad clamp or something. Unusual on a stock truck
1995 F-350 Dually, 4x4, auto, 4" straight pipe, aFe intake, DP tuner. 357k miles still original motor!
2004.5 2500 cummins 4x4, auto, 5" DE, K&N, smarty s06 POD. (not that anyone on this forum cares)
diesel_forever is offline
post #4 of 12 Old 07-01-2014, 08:43 PM
RJC2's Avatar
Quoted: 314 Post(s)
I just had a 6.0 flashback!
2017 F350 CCSB King Ranch Ultimate 6.7
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler, CTS Insight monitor,
RJC2 is offline
The Following 2 Users Say Thank You to RJC2 For This Useful Post:
Heavy_GD (07-02-2014), texaslimeaide (07-01-2014)
post #5 of 12 Old 07-02-2014, 06:33 AM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
this truck is all stock and on their website says it throws CEL if you dont have a tuner on the truck.....
whats weird is it blew without romping on it and wasnt towing anything. unless it was close to blowing from the day before towing and it finally let loose. after tightening it back down they towed the bobcat back home without any problems. i told him to ease into the boost and not spike it up so we will see i guess.
T-rav
2010 F350 6.4-
travisH3 is offline
post #6 of 12 Old 07-02-2014, 06:51 AM
Travis:
Having the boots blow off on any brand of diesel pickup is not uncommon.
I drag race a 1996 Dodge CTD 12 valve with a fully built Scheid Diesel 5.9
Cummins. The truck has twin turbos, can make 80lbs of boost (wastegated)
and will turn 5,000 RPM. I went through ALOT of different diesel vendors trying to find silicone boots that could hold my high boost. I FINALLY found some that IMHO are the best on the market. They come from Piers Diesel or,
PDR Diesel out of Canada. Here is a link for you if you are interested:
Boot Kits! - PDR
Let me tell you, these boots are TOUGH!! They will also send you some very good clamps with them,...which IMHO,...is about as important as the silicone boot itself. On my drag truck, I actually have to "double clamp" the boots on BOTH sides! Piers Harry, founder and owner of PDR is a great guy and has been in the high performance diesel business for many years.
Hope this hepls you Sir!
John_P
2014 Ford F-250 Super Duty, 4WD, Crew Cab, Lariat Ultimate, FX4 6.7 "Scorpion" Turbo Diesel
John_P is offline
post #7 of 12 Old 07-02-2014, 08:00 AM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
Originally Posted by John_P View Post
Travis:
Boot Kits! - PDR
John_P
yeah im aware of boots blowing off i just wanted to make sure there wasnt a problem since how it happened wasnt under load or anything. hopefully taking it back apart and cleaning it off good will keep it sealed and from blowing off. truck doesnt make a lot of boost lol. its a 450 cab and chassis and i think it only runs like 25psi of boost so you'd think i would have much of a problem where as my 6.4 i can peg the boost gauge easy and ive never blown a boot, KNOCK ON WOOD lol
T-rav
2010 F350 6.4-
travisH3 is offline
post #8 of 12 Old 07-02-2014, 08:53 AM
Not unusual at ALL. We all carry spares in our service trucks(F-550) due to breaking so many of them. Its a POS design. You got lucky if it only blew the hose off and didnt break the crappy plastic connector going into the throttle valve assy.
Looked into swapping to the H&S setup, but it requires you to remove the throttle valve and must utilize aftermarket programming...
The hose isnt covered by the 100K mile warranty either.
poormanscat is offline
post #9 of 12 Old 07-02-2014, 11:32 AM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
wow... do any pieces go into the intake when that happens?
T-rav
2010 F350 6.4-
travisH3 is offline
post #10 of 12 Old 07-02-2014, 11:43 AM
sprksonu's Avatar
Travis:
Boot Kits! - PDR
John_P
thanks for the link! just ordered a set for my 6.0, tired of the riff raff boots.
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
