F350 level - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By salnazzaro
post #1 of 10 Old 06-29-2014, 04:09 PM Thread Starter
F350 level
Anybody out there level a 350 with 2 1/2? I just bought a 15 350 and it looks to me like 2 1/2 wil be a little too much I wanna do a icon but It looks to me like 2 would be the ticket . I don't wanna be front high.. Any real world advise or suggestions?
jrod350 is offline
post #2 of 10 Old 06-29-2014, 04:52 PM
Quoted: 25 Post(s)
I am sitting on a 2.5" leveling kit and the front is still lower than the rear by just a little. I think a 3.5" kit might get it dead level. Also, I am running the stock 18" wheels and tires.
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #3 of 10 Old 06-29-2014, 05:32 PM Thread Starter
What kinda kit did you go with?
jrod350 is offline
post #4 of 10 Old 06-29-2014, 06:03 PM
salnazzaro's Avatar
Quoted: 23 Post(s)
I've got ready lift 2.5s up front, had to add icon 5" rear blocks since it was too low for me in the rear
sabarnes likes this.
2015 f350 cclb platinum...5% tint, Anzo smoked mirror lights, recon clear cabs, tgc 2.5" spacers, carli adjustable track bar, icon 5" rear blocks, Firestone riderites, B&W goosneck, line x, rancho 7000s, Fuel Mavericks wrapped in Toyo MT's, 4" flo pro straight pipe, Sct w gearhead tunes, hideaway LEDs
salnazzaro is offline
post #5 of 10 Old 06-29-2014, 07:07 PM
Quoted: 25 Post(s)
I went with a Custom Diesel kit from Amazon. It did come with shock extensions but not brake line relocation brackets. I wasn't ready to buy shocks at the time and I wish I would have thought to buy a kit with the relocation brackets. I ended up drilling and tapping new mounting holes for the brake lines, so no big deal. This kit goes on top of the spring and some others go under it. I don't think one is better than the other, but maybe.
post #6 of 10 Old 06-30-2014, 10:02 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
We have a 2" coil kit that's complete with shocks, Castor shims and a adj track bar. PM me if I can help.
CT Performance, Inc. is offline
post #7 of 10 Old 06-30-2014, 11:21 AM
raftdaddy's Avatar
i have the ready lift 2.5 with track bar bracket. 2.5 puts you perfectly level but looks nose high due to the wheel wells. and if i hook anything up to the rear it is nose high when pulling. I have the camper package and the rear was real high. looks like it takes 2 inches to suck up the slack for the add a leafs take over. i would imagine ford made it so it rides level when pulling so adding a couple inches in the front is how high it is when pulling.[IMG][/IMG]
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
post #8 of 10 Old 06-30-2014, 11:50 AM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
My 350 sits almost perfect stock i think you're rite 2.5 will be too much, I think you will need to use a SRW 350 block and then a 2.5 inch spring in the front and i think it would be perfect and you will be 2 inches higher all the way around
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #9 of 10 Old 06-30-2014, 11:52 AM
Carli'd6.7's Avatar
Or is your truck a SRW?? haha cuz if it is a 2.5 spring is perfect i did it to my 13 F250 and it was 1/4 inch lower in the front with 2.5 in the front and stock 350 block in the rear and clears 35s perfectly
post #10 of 10 Old 06-30-2014, 02:06 PM
Randy_270's Avatar
Quoted: 2 Post(s)
Just an fyi, if you go with new front coils it doesn't always add 2.5" of lift. They are designed to level the front of the truck with either a factory f350 block or a 4" block. So if your truck is only 1" higher in the back than the front and you change out the coils with 2.5" leveling coils its not going to make your truck 2.5" higher than it is now. If your truck is again 1" higher in the back and you add a 2.5" spacer up front then yes it will be taller in the front than the back.
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
