Takeoff shutter when towing a heavy trailer - Ford Powerstroke Diesel Forum
post #1 of 28 Old 06-26-2014, 06:39 PM Thread Starter
I can confirm that airbags solved the takeoff shutter when towing my heavy toyhauler with my 2012 SRW F350 4x4. Used the Firestone Ride Rite airbags.
joeyou is offline
post #2 of 28 Old 06-27-2014, 01:59 AM
Drivin the 6.mOney pit
armyguy209's Avatar
Feedback Score: 6 reviews
Do the trucks ride smoother with the air bags? I thought about doing some really soft springs to get the truck to ride smooth, and then have the airbags for towing.
Dan's baby
2006 F250 CCSB Lariat 4x4 with 2007 CR 5.9 Cummins/built Allison swap and other goodies-sold
2015 F350 CCSB 4x4 Lariat Ultimate in Black tuxedo metallic
US ARMY VET
Operation Iraqi Freedom III (1 YR served in the good ol' sandbox)
armyguy209 is offline
post #3 of 28 Old 06-27-2014, 05:05 AM
cd4899's Avatar
It will ride so much smoother with the air bags! Best upgrade that I have done to my truck.
2012 F350, Lariat, FX4, CCSB, ReadyLift 3.5" SST, 37" Toyo Mt, BMF Novakanes 20x9's, Firestone air bags, Air-Lift 72000, Rigid D2's
cd4899 is offline
post #4 of 28 Old 06-27-2014, 05:26 AM
TW720HVY's Avatar
Quoted: 2 Post(s)
Has anyone installed these on their trucks? I had a set on my old GMC Duramax, it was one of the best additions I did to that truck! My 350 has an overweight spring that will have to come out if I do this and was just wondering if it would be worth the hassle.
Roadmaster Active Suspension Kits | Helper Springs | Overload Springs
Previously Owned
2011 F-350 Lariat Crew Cab, White with Black interior, SRW, Short Bed, FX4
TW720HVY is offline
post #5 of 28 Old 06-27-2014, 07:05 AM
dagnabit9's Avatar
I had the Firestone Ride Rite airbags in my previous truck and now in this one. I think it is, hands down, the best mod you can make to your truck to help improve the ride, level the truck, and keep the truck from squatting and bottoming out. And all of it accomplished with ~60 PSI in the bags; I carry an air tank with me when I'm towing so if I need to unhitch from the trailer, I can let the air out of the bags and then re-inflate them when I hitch up again.
USAF Retired (2P071)
2011 F250 KR FX4 4x4 CC SB
2006 F250 XLT FX4 4x4 CC SB, EGR Cooler Delete, AutoMeter Gauges, Scangauge II, SCT x3 Custom Tunes - SOLD!
2009 Keystone Raptor 33' Toy Hauler Fifth Wheel
2006 H-D ElectraGlide Ultra Classic
dagnabit9 is offline
post #6 of 28 Old 06-27-2014, 07:32 AM
Quoted: 3 Post(s)
my truck already has a lift (level kit) on it. F250 with icon spring in front and f350 blocks in the rear. will the airbags give it a rake when not towing?? i want the smoothness for when i pull the 5th wheel, but dont like the nose down look...
Whskiles is offline
post #7 of 28 Old 06-27-2014, 08:08 AM
mor4wd's Avatar
You're supposed to keep 5 psi in the bags when you aren't needing them. This shouldn't affect ride height. I know it doesn't on mine. Airbags really only help smooth the ride when you have a load. When you're running empty with 5 psi in the bags they really don't do anything for the ride quality. If anything, they make it harsher. You can get a smoother empty ride by removing a leaf from the pack and leveling the truck with the airbags though. Remember, the bigger the bag, the smoother the ride.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #8 of 28 Old 06-27-2014, 11:51 AM
Quoted: 3 Post(s)
Good to know but I am swapping for a Dually. I have a Voltage 3950 and my SRW F350 shudders like a wino on a Sunday morning when taking off. Hoping the 4:30 rear end and other necessities of the F450 will solve the issue. Better.
2016 Ford F-350 King Ranch 4x4 Super Crew 8 Foot bed. 2014 F-150 Super Crew 6.5 Foot bed 4x4 Platinum.
MisterScott is offline
post #9 of 28 Old 06-27-2014, 12:08 PM
cd4899's Avatar
I actually found that if I run 10 psi in the bags while empty, I would get a better ride than with 5psi. As far as rake to the truck, I don't like the nose down either so my truck stays level while towing or not. I run the Firestone bags with on board air compressor. Just a push of a button to change the air pressure.
cd4899 is offline
post #10 of 28 Old 06-27-2014, 01:46 PM
Quoted: 279 Post(s)
Just an FYI, Ford changed the rear axles partially into the 2015s to fix the shudder that people experience on take off. There is no more shudder (the first batches of 15s did not have the updated axle).
15 6.7 F350 CCSB 4x4 Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2, Dieselsite fuel filter, DeeZee tailgate assist, Hellwig Rear Sway bar, Bilstein 5100s
**Support the Online Vendors!!! Want your best price, buy from Scott Pratt!! Get your truck in 3-4 weeks, order to delivered!!
blwnsmoke is offline
