sensor modules on frame - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-22-2014, 04:12 AM Thread Starter
What is everyone doing with the sensor modules along the frame when they delete? I took mine off.
lizardking is offline
post #2 of 12 Old 06-22-2014, 10:42 AM
I left all mine in place.
Horms07 is offline
post #3 of 12 Old 06-22-2014, 10:52 AM Thread Starter
I was thinking that some were taking them off and just tying up the harness.
post #4 of 12 Old 06-22-2014, 01:45 PM
08TitanSE's Avatar
Quoted: 6 Post(s)
Remove the EGT probes so you can reuse one of them under the hood if you EGR delete. The rest just zip tie them completely out of the way.
2014 F-250 4x4 Lariat
Ruby Red Metallic
6" Lift, Icon Shocks/Steering Stabilizers, 37 Toyo M/T
Amp Steps, Anzo U-Bar Headlights, Bushwacker Extend-A-Fender flares
H&S Mini Maxx, 5" Flo-Pro, Sinister EGR Delete, No Limit 5" Intake
Gearhead Tunes, Ford Remote Access
The list goes on and on and on
2003 Mustang GT Vert/523RWHP/470RWTQ
Way too much to list
08TitanSE is offline
post #5 of 12 Old 06-22-2014, 04:15 PM Thread Starter
I'm not using the EGT all. No need for a daily driver.
post #6 of 12 Old 06-22-2014, 04:23 PM
08TitanSE's Avatar
Quoted: 6 Post(s)
Maybe there's no need but with the H&S it's simply a matter of one sensor being placed in the EGR exhaust plate and plugging it into the factory EGT sensor plug. There's no running wires, extra work, etc. so why not?? It was there so I took advantage
Ruby Red Metallic
post #7 of 12 Old 06-22-2014, 05:25 PM Thread Starter
I have the XRT so it's not an option for me.
post #8 of 12 Old 06-22-2014, 05:25 PM Thread Starter
Did you leave your module boxes on the frame then? Just curious
post #9 of 12 Old 06-22-2014, 05:51 PM
Quoted: 27 Post(s)
Unplugged the sensors, covered the connectors (in tape in case I need them later) and tie-wrapped them to the frame rail. The boxes and sensors stayed in place. I will try the EGT sensor in the EGR plate to see if it will work with the CTS, but I may have to go with the EAS EGT probe.
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #10 of 12 Old 06-26-2014, 11:43 PM
HighHP's Avatar
Took all the modules and sensors out with the exhaust, tied any plugs that were attached to the main harness up with zip ties. Figured less ugly **** up under the truck the better.
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
