2015 turbo on a 2013 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-28-2014, 05:44 PM Thread Starter
My '13 6.7 has turbo surge issues and I'm curious if the '15 turbo will be compatible with the older model 6.7s?
highmileage is offline
post #2 of 6 Old 01-28-2014, 07:08 PM
Cratos's Avatar
I herd the fuel system is different on the 15 also.so I don't think it will work.
2012 F-250 4X4 FX4, SCLB, 3:55's , Camper & Tow package, air lift bags and pump, Edge insight. Dark Pearl Blue.
Cratos is offline
post #3 of 6 Old 01-29-2014, 08:07 AM
TX_TRU_STUD's Avatar
Quoted: 52 Post(s)
subbed.....i wondered if this would work with new fuel system and ECM update.
TX_TRU_STUD is offline
post #4 of 6 Old 01-29-2014, 06:53 PM
HighHP's Avatar
I think anyting is possible with tuning, Im more curious what the 15 will have for exhaust manifolds and turbo mounting, the problem we run into with the 11-14 trucks is the goofy turbo with 2 inlets on the turbine side. I wonder if the 15+ trucks will stick with this goofy azz setup or go to the tradition single in mount. I think either way if tuning is involved and possible exh/int mounting issues your better off looking into an aftermarket solution for a different turbo. I been looking into the MPD kits, I really like what they have done with the exhaust for their kit. It changes you over to a T4 flange so you can run virtually any aftermarket turbo with that flange style and the kit also has the option of going with a 63 or 66mm turbo, Im pretty sure the 15s will have a 67mm so this kit is going to be close. If the 15 turbo is a drop in swap it might be worth it, if not then Id look into the MPD kit.
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #5 of 6 Old 01-30-2014, 08:33 AM
barobbin's Avatar
Quoted: 3 Post(s)
I'm sub'd for an update
barobbin is offline
post #6 of 6 Old 01-30-2014, 12:09 PM
fordtrix's Avatar
Once they actually release the 15 info someone will be able to answer. In the meantime its all speculation.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
