Will 35x12.5 fit on stock 20's? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-25-2014, 11:32 AM Thread Starter
Been thinking of getting different tires, want larger ones. Been to several tire shops but one told me that 35x12.5x20 won't fit I. The stock 8" wheels. Only one shop said this.
Can anyone confirm?
Thanks!!
Leclerc457 is offline
post #2 of 11 Old 01-25-2014, 11:45 AM
They fit fine. Have them on mine
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #3 of 11 Old 01-25-2014, 12:15 PM
PSDJohn's Avatar
Look around here you'll find a bunch of people running that setup.
2011 F250 XLT SCLB FX4 35k miles
H&S XRT Pro, Diamond Eye 4in straight pipe, 6in MBRP tip, S&B CAI, Edge Insight CTS, H&S egt kit.
Readylift stage 3 2.5in, 20x10 -24 Fuel Hostages, 35/12.50r20 Toyo MTs, Recon Cabs and Mirror lights.
Back Rack, TSC toolbox, Realtree seat covers.
PSDJohn is offline
post #4 of 11 Old 01-25-2014, 01:23 PM Thread Starter
Brett, did you install a leveling kit? I have a 2013 F-350, I'm thinking they will fit without one but just wondering.
Thanks!
post #5 of 11 Old 01-25-2014, 01:34 PM
POWERCHOKER
Dantron's Avatar
I would think there would be contact issues if you didn't level up the front. At least that's what I've been told. I thought you were more concerned with the 12.5" wide tire mounted on the 8" wide wheel. I have a Toyo 37x13.5x20 mounted on a stock wheel, but I'm only using it as the spare.
Dantron is offline
post #6 of 11 Old 01-25-2014, 02:24 PM
Not sure if you have the 250 0r 350 but my Brother In Law has this exact setup with Nitto Trail Grapplers on his F250 King Ranch and has no rubbing or any issues at all and he uses his truck for work and does a lot of traveling down really rough back roads for oilfield work. If they work on his without any issues they should work on any of them I would think, he is bone stock with exception of the 35x12.50x20 Nitto's...
KENNY
2013 F250 Platinum Tuxedo Black
3.5" Ready Lift
Firestone Air Bags
20x10 BMF Novacane DMB
35x12.50R20 Toyo MT
kennyketten is offline
post #7 of 11 Old 01-25-2014, 04:34 PM
Thanks!
I ran them before I lifted my truck zero issues. They looked good too. I have 35/12.5/20 cooper sst tek3. I have since added a 4" PP triple threat lift and it's even better!
Brett
post #8 of 11 Old 01-26-2014, 03:43 PM
brdgraf's Avatar
Like said they will fit no problems here either. No lift no rub on mine
Sent from AutoGuide.com App
2012 F-250 6.7L Lariat CC White platinum and pale adobe two tone
AFE Pro dry intake
Recon smoked cab running lights w/ amber LED's
Recon smoked mirror side lenses w/ amber LED's
brdgraf is offline
post #9 of 11 Old 01-27-2014, 07:28 AM
a2designs's Avatar
Quoted: 10 Post(s)
Can anyone confirm?
Thanks!!
http://www.powerstroke.org/forum/gen...k-20-rims.html
'16 F-350 CCLB Platinum
a2designs is offline
post #10 of 11 Old 10-06-2015, 07:49 PM
Is this the case with a 2015 F350 4x4 that came with 275/65/20's? I want to keep the King Ranch wheels but go to 35x12.5x20's? Is this a problem? Will they fit the stock wheels?
KingRanch2015 is offline
