Engine Block Heater Temps? - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 31 Old 01-24-2014, 12:12 PM Thread Starter
TX_TRU_STUD's Avatar
Quoted: 52 Post(s)
I "used" my engine block heater today and I don't think its working. The temp outside is 38* F in TX. I show on the temp gauge in the dash it says its 41*F. How much does the heater raise the temp? It has been plugged in for hours, 6 probably. I know you are supposed to use it in really cold weather but I wanted to see if it worked and if so by how much.
TX_TRU_STUD is offline
post #2 of 31 Old 01-24-2014, 12:55 PM
raftdaddy's Avatar
that's too warm for the block heater,you can burn it out. but you wont be able to tell a difference unless it's cold out. it just keeps your block warm,like not frozen kinda warm. but the easiest way to check is at night pull it in and out and look for the light blue spark or put an ohm meter on it and check for resistance. i'm not sure if our trucks have thermostats built in like the chevy's do. I would not plug in till below freezing, - 15c or I think about 5 f.
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
post #3 of 31 Old 01-24-2014, 02:11 PM
doczenith1's Avatar
Quoted: 7 Post(s)
Take a look at the supplemental heater link in my signature. There's a comparison between plugged in and not plugged in. I think the difference in oil temp was about 30 degrees F at startup.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
post #4 of 31 Old 01-24-2014, 03:02 PM
Thats a very impressive fuel mileage spread sheet you got there hand. Now thats keeping up with whats goin on...
KENNY
2013 F250 Platinum Tuxedo Black
3.5" Ready Lift
Firestone Air Bags
20x10 BMF Novacane DMB
35x12.50R20 Toyo MT
kennyketten is offline
post #5 of 31 Old 01-24-2014, 03:06 PM
raftdaddy's Avatar
that's interesting. I honestly have never checked cause if i'm plugged in I gotta be!! I have a clear end with a light on my cord and it sparks blue when I plug in. I'm an electrician so I know if a heating element is drawing ,its working. no sparking no draw. I wonder if there is a difference in trucks? I see it was done in 2010 I wonder if it was a 6.4? but your best bet is check it with an ohm meter.sorry I can't be more help. it is interesting though!! hopefully someone will chime in with actual oil temps
post #6 of 31 Old 01-24-2014, 03:08 PM
raftdaddy's Avatar
and 3.30 a gallon is sweet!! we are 5.60 and winter crap hurts the milage!!
post #7 of 31 Old 01-24-2014, 03:45 PM
Been below 0 here for the past few nights, and I notice my engine oil temp comes up WAY faster and I get heat in the cab a lot sooner when the truck is plugged in. The engine starts no matter what but when it's really cold the truck starts a little easier and definately sounds a little better when I first start it when it's plugged in.
Does the block heater just go in the side of the block in one of the freeze plug holes like the block heaters on big equipment?
hilton850 is offline
post #8 of 31 Old 01-25-2014, 07:24 AM
How would you burn out the block heater? If it's under 35 I plug my truck in. To the op, my oil temp is usually 30 degrees above the outside temp...unless the wind is blowing hard then it is closer to the actual temp.
2012 f250 Ccsb Ultimate Lariat, Powerstroke FX4- Tuxedo Black, Bakflip F1
Lrdchaos is offline
post #9 of 31 Old 01-25-2014, 07:41 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I always thought wind chill was for "alive" objects and wasn't affected by sheet metal and glass etc... That's why it's always warmer in the truck when the wind is blowing sideways vs being directing outside.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #10 of 31 Old 01-25-2014, 08:06 AM
That's what I have heard as well. I just know that when the wind blows my oil is closer to the actual temp than when it's is not blowing.
Lrdchaos is offline
