Titan Tank pukes out of breather when filling up - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-20-2014, 08:23 PM Thread Starter
Quoted: 2 Post(s)
Hey guys my titan tank pukes fuel out of the vent / breather each time I fill the truck up. I am not topping it off, I stop fueling when the pump stops.
I have pointed the vent upwards as best I can.
Anyone else ever run into this problem?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 3 Old 01-21-2014, 12:19 AM
Long Member
TMAG6.0's Avatar
I dont know how your trucks plumed in but my boat did this. On the boat, due to slack, the vent line made a U bend before the tank creating a "water seal" like on a sink drain. As you fill the tank pressure builds until it pukes the material out of the U. i fixed this by running the drain up from the hull then downhill to the tank. This keeps water out from one side and fuel out from the other. No more liquid in the hose to puke out. Check your vent hose and make sure you have a smooth uphill all the way to its destination
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click
to save a childs life.
TMAG6.0 is offline
post #3 of 3 Old 01-21-2014, 02:00 PM Thread Starter
Quoted: 2 Post(s)
I'm pretty sure it is plumbed exactly like the instructions say. I might ask titan also.
Anyone else ever had this happen?
wreedPS is offline
