Anyone else have this problem - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-19-2014, 09:08 AM Thread Starter
HPUyellowjacket's Avatar
I'm tired of these having to be put back on almost every time I drive. Does this happen to anyone else?
New Truck
2012 Lariat FX4 Off Road, Tuxedo black, Custom paint to match grille, paint to match halo projector headlights, S&B intake, Amp Steps, RBP 94R black with chrome insert 20X9 wheels, 35 Nitto Trail grapplers
The Toy
2001 4x4 off-road extended cab, DP tuner, 4 inch turbo back, S&B filter, smoked projector headlights, Ranch hand fron & rear replacements, 18 inch fuel wheels, nitto trail grapplers.
HPUyellowjacket is offline
post #2 of 13 Old 01-19-2014, 10:01 AM
Hoverp's Avatar
Yes! And I noticed it after I drove my truck home 250 miles from the dealership. The dealership put in a line x spray in liner and now the little Tabs are to short to keep the covers on so what I did was to buy a rubber bed Mat and put the covers on and then put the rubber bed mat over the top of them that holds them down but yes I have the same problem.
2014 F350 CC Short bed, Fully loaded, Platinum Edition. 6.7L Scorpion Tuxedo Black. 3.55 ELD, FX4, Sup heater, 5th package , BFG Radial All Terrain: icon_ford:
Hoverp is offline
post #3 of 13 Old 01-19-2014, 11:38 AM
GLIofMI's Avatar
Not I. There's a B&W hitch sitting there, no problem. LOL!
283K, Still Runnin
GLIofMI is offline
post #4 of 13 Old 01-19-2014, 03:28 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Gotta be your Liner causing this. I have no Liner and have never had this issue, wish I could give you a suggestion on a fix, good luck.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 13 Old 01-19-2014, 04:26 PM
Quoted: 3 Post(s)
I just solved this issue coincidently. I have a spray in liner as well and went to put them on and there was not way they were going on without destroying them. The lip of the plastic ring needs to fit in a lip on the 5th wheel ring coming through the bed. Bed liners make it more problematic as it raises the bed level enough to be an even bigger pain.
What I did was stick the 5 pieces on a baking sheet and place them in the over on the lowest setting, about 150F I believe for about 10 minutes. I removed each one at a time and ran out to the back of the truck and snapped them in place by starting on one side and ringing it around the 5th wheel piece. I also used a rubber mallet to make sure the flanges where as flat as could be on bed while warm right after I snapped it in. I took me almost a year to finally get around to putting them on because I tried a few times when they were cold and there was not way. Try at your own risk but it worked great for me and they have not popped off.
2016 Ford F-350 King Ranch 4x4 Super Crew 8 Foot bed. 2014 F-150 Super Crew 6.5 Foot bed 4x4 Platinum.
MisterScott is offline
post #6 of 13 Old 01-20-2014, 05:50 AM
I had the same problem with mine... solved the problem by replacing them with these caps.
HOME
lpshiner is offline
post #7 of 13 Old 01-20-2014, 02:07 PM
What year is your truck?? I have a 2012. I Zoomed in on that picture of yours and the caps and the top of the gooseneck look different then mine. Basiclly the cap seems to go out around the hitch where on mine there is a part of the cap that gets pushed down into the inside. I got to grab a screw driver every time just to pop them out.. If there is differences threw the years I wasn't aware of it..
Jason1Pa is offline
post #8 of 13 Old 01-20-2014, 03:43 PM
ucpa111's Avatar
Quoted: 3 Post(s)
I had a spray in liner put in and mine do the same thing. The liner added heigh which reduces engagement. Yes...it's a pain. No, I haven't done anything about it yet. No, I probably won't spend $100+ fixing the issue (although the CNC machined ones listed above do look good).
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #9 of 13 Old 01-20-2014, 06:11 PM
Hoverp's Avatar
I guess a guy could always take a Xacto knife to the bed liner around each opening and make a cut, or feather it down to where the caps would sit low enough to engage the bed.
Hoverp is offline
post #10 of 13 Old 01-22-2014, 08:40 AM
kdskidoo's Avatar
my 2011 is the same way as your 2012. when I bought the truck the plugs weren't in the hitch, but I found one laying inside the cab in the back. my truck has a spray in liner and the plug fit tight and I needed a screwdriver to get it out. I only have 3 holes instead of 5. I'm assuming this is for a gooseneck hitch only. I've always used a bumper pull trailer so I'm not familiar with the 5th wheel or gooseneck hitches.
2007 F 250 superduty Highline Pkg.
10" lift-Rock Krawler coil over 4 link pre-runner system w/ Fox res. shocks all around
dual BDS steering stabs
custom trac bars w/polished stainless inlay w/"FORD" lazer cut in center and flames on ends
Raptor coating on frame axles, etc.
bushwacker pocket style fender flares
Jesse James Lawless 18 X 10 chrome wheels
38.5 X 14.5 Pro Comp Xtreme mud tires
AMI Billet door handles and fuel door
4" turbo back stainless exhaust w/ 5" tips
much more to come
kdskidoo is offline
