Re-Gen Notice - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-17-2014, 03:18 AM Thread Starter
camper99's Avatar
Re-Gen Notice
Hi. I only have my 2014 F250 Lariat for 350 miles so far. This morning I notice the mpg were dropping and I thought it was in re-gen mode but did not see where to find if this was it or not. I am comming from an 2008 f350 xlt that I had to push the reset button to see if it was still in re-gen mode. Thanks.
camper99 is offline
post #2 of 14 Old 01-17-2014, 04:23 AM
boatpilot's Avatar
The notice only pops up for a split second in the instrument cluster, no need to acknowledge it and pretty much the only way to know if it is in regen mode is to catch that msg. and dropping mpg...congrats on new truck
2012 F350 KR
Carli 4.5 Performance, Machined Fuel Kranks 17", 37" Toyo MT's, H&S Mini with custom tunes, H&S Cac, S&B CAI, 5" FLOPRO, EGR/DPF delete, Full replacement front and rear bumpers, toolbox, and bedrails by South Texas Outfitters, Rigid LED's, B&W hitches...and this thing is finished!
boatpilot is offline
post #3 of 14 Old 01-17-2014, 05:56 AM
Boompats's Avatar
Exactly what he said. Wish there was a way to verify, but just look for the 6 to 8mpg on the cluster.
Boompats is offline
post #4 of 14 Old 01-17-2014, 06:13 AM Thread Starter
camper99's Avatar
Thanks. Sometimes I would drive the extra 3 to 4 miles on my other truck so it would finish the re-gen before I parked it at home. No need to finish the re-gen now?
camper99 is offline
post #5 of 14 Old 01-17-2014, 07:40 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Correct. The Regen process will resume the next time you drive your truck. Unless the message center tells you to Drive to clean exhaust filter than don't worry about it. Now saying that, if you drive primarily short trips, then make sure once a week you take her out on the highway and drive her for a good hour or more at highway speeds, Diesels Love to be ran!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 14 Old 01-17-2014, 07:42 AM
It does help to finish the regen, because otherwise it will start up midway through your next drive. It won't hurt anything to stop it in the middle, but you'll eventually want to let it go through a full cycle. However, Ford didn't really give us any monitoring capability stock. If I have the time, I also like to go ahead and let the regen finish. If I notice MPG down, I usually drive another 10 minutes or until the MPG returned back to normal. It's much easier to tell at highway speeds, so I hop on the loop or get to the edge of town.
I have added an Edge Insight, and it has an indicator letting you know when regen is occurring as well as ability to display DPF soot concentration so you know when it's coming. I had to call them up to get it to work with my 2014 (they tricked it into reading it as a 2013, and it seems to work); they'll probably have an update out later this year to fully support the '14s.
--nathan
2014 Tuxedo Black, 6.7L Lariat FX4, Nav, 20" aluminum wheels
siver_pilate is offline
post #7 of 14 Old 01-17-2014, 08:57 AM Thread Starter
camper99's Avatar
Thanks all. This is good information to know.
camper99 is offline
post #8 of 14 Old 01-17-2014, 09:36 AM
Quoted: 4 Post(s)
Not a problem, that's what this Forum is all about.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #9 of 14 Old 01-17-2014, 01:55 PM
HighHP's Avatar
I went from running my CTS in my old 08 ram 1500 to my 13 350 and its crazy how much more you can monitor on the diesels. The ability to monitor DPF load is worth its weight in gold. Id definitely recommend anyone with a new truck buy a CTS before any other mods!
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #10 of 14 Old 01-17-2014, 04:36 PM
boatpilot's Avatar
Short answer is to delete...period!
2012 F350 KR
