Installing Bilstein 5100s - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-11-2014, 08:37 AM Thread Starter
Quoted: 2 Post(s)
Guys, I will be installing these shocks either this afternoon or tomorrow depending on rain. Does anyone know if there are any specific torque specs? The one I'm most curious is the tops of the front shocks.
Stock for now.
Bluwaterbrew84 is offline
post #2 of 14 Old 01-11-2014, 09:17 AM Thread Starter
Quoted: 2 Post(s)
Also, How do you remove the center caps from the lug nuts? It looks like they would just pry off by I don't want to damage them.
Stock for now.
post #3 of 14 Old 01-11-2014, 09:57 AM
Quoted: 11 Post(s)
I installed 5100's on my truck a few months ago. Why are you asking about the center caps? I didn't have to take my wheels off or even jack the truck up.
Drewtk is offline
post #4 of 14 Old 01-11-2014, 10:00 AM Thread Starter
Quoted: 2 Post(s)
I was going to take them off when I do the fronts just to make its easier. I know it isn't necessary. I am also curious in case I ever need to change a tire on the side of the road. I am a GM guy, this is my first ford and the center caps are different.
Stock for now.
post #5 of 14 Old 01-11-2014, 10:17 AM
steelnc's Avatar
Find the little notch on the side of the center cap and just pry it back. Wrap a cloth around whatever you use so it doesn't scratch the wheel.
2014 F250 Platinum
4" Pure Performance lift
20x10 Novas 35" Toyos
Mini Max
5" Flo pro
steelnc is offline
post #6 of 14 Old 01-11-2014, 10:34 AM Thread Starter
Quoted: 2 Post(s)
Thanks, that's what I figured. Just wanted to make sure b4 I started prying
Stock for now.
post #7 of 14 Old 01-11-2014, 11:10 AM
TW720HVY's Avatar
Quoted: 2 Post(s)
I am so ready to put these on my truck!
Previously Owned
2011 F-350 Lariat Crew Cab, White with Black interior, SRW, Short Bed, FX4
TW720HVY is offline
post #8 of 14 Old 01-11-2014, 11:22 AM
fordtrix's Avatar
When you tighten the top nut, tighten it until you see the rubber insert compress till it's a bit rounded.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
The Following User Says Thank You to fordtrix For This Useful Post:
Tweez (01-11-2014)
post #9 of 14 Old 01-11-2014, 02:58 PM
raftdaddy's Avatar
the fronts are easy to do wheels on. took me an hour in my driveway. what I did was just look at the compression of the stock rubber and duplicate it with 5100 on. as you cant get a torque wrench on it as there is an allen wrench on top to hold the shaft. what I did was knock the nut off the top washer and use the stock rubber and washers. you will see the why I did it when you take it apart, but i'm sure not necessary. and also your tire wrench should have a rubber curved end end on it for popping center caps off. my 2010 did anyway have not looked at my 12.
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
post #10 of 14 Old 01-11-2014, 03:41 PM Thread Starter
Quoted: 2 Post(s)
Thanks for the info guys! I went out to start on them today but the bottom fell out and rained the rest of the day. Hopefully I will have enough sunshine to do them tomorrow.
Stock for now.
