System monitor for a 2014 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-07-2014, 10:47 AM Thread Starter
I am looking for a good system monitor for my 2014 Lariat.
I recently purchased an Edge Insight CTS as the Amazon supplier I purchased through claimed compatibility all the way through 2014. Well, that's partly true and mostly a lie. Sure, if you want to monitor RPM or speed or other less-than-helpful PIDs, it will work under a generic model. If you actually try and get it to monitor Ford PID's, the thing won't even turn all the way on when connected. It simply turns off as it tries to load the gauges. I updated through their software (which doesn't support macs ), but no dice. I called Edge, and got no help. The vague CS rep basically suggested to shelve it and hope an update comes out, even after telling me that it would "probably be quite some time" before they have support for 2014 . These trucks have been on the road for months, yet I doubt I see support until at least middle of the year. I can't have my money sit idle that long. It's my fault for not checking into it in more detail, but frustrating all the same.
So does anyone have experience or know of a good system monitor that doesn't require having a lap top hooked up (I can't really watch the laptop while driving and towing)? I'm looking to monitor available EGT's, ECT, soot level/regen status, fuel system status, pull major codes, etc. Does anyone make anything that actually works with a 2014? Thanks!
--nathan
2014 Tuxedo Black, 6.7L Lariat FX4, Nav, 20" aluminum wheels
siver_pilate is offline
post #2 of 4 Old 01-07-2014, 11:02 AM
steelnc's Avatar
--nathan
I didn't know the Cts wouldn't work on the 14's. Not sure it's real critical to monitor anyway like the two previous engines. I'm pretty sure you can see oil temp, coolant temp, and trans temp on the factory gauges. If you ever have any intentions on deleting maybe just buy the mini max.
2014 F250 Platinum
4" Pure Performance lift
20x10 Novas 35" Toyos
Mini Max
5" Flo pro
steelnc is offline
post #3 of 4 Old 01-08-2014, 04:31 PM Thread Starter
I got a response back from a different rep on the insight. He said to give then a call when I could be around the truck and computer, and they would give something a try. They basically loaded a firmware update that defined a VIN for a 2013 to trick it into thinking the truck is a 2013. It was a shot in the dark, but it worked. I haven't had a great deal of time with it to see how reliable it is, but it seems to be working so far. It has reset randomly when running a few times, so it's a bit quirky, but it's reading the PIDs.
Problem solved for now.
post #4 of 4 Old 01-08-2014, 04:37 PM
steelnc's Avatar
Good to hear. Hopefully it holds up for you.
2014 F250 Platinum
Mini Max
5" Flo pro
steelnc is offline
