2015 F250/F350 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-30-2013, 01:19 PM Thread Starter
cjf250sd11's Avatar
Quoted: 2 Post(s)
2015 F250/F350
Quite a few nice upgrades to the powertrain on the '15. The speculation is 450hp/900tq with the new turbo setup. I just read where the order acceptance date is 1/15/14 which adds up since I have been reading that 2014 will be a short model year run as the final order date is 1/06/14.
Anyone have anything further to add?
2015 Ford F-series Super Duty Photos and Info ? News ? Car and Driver
2014 F250 4x4 Platinum, Black Tuxedo Carli Commuter Fox 2.0 & Steering Damp, PP 4-link, Fuel Maverick 20x10 - 5" BS, Toyo Open Cntry AT II 35x12.50, Recon LED Smoked Tails, 3rd Brake, Cab & Mirror Lights
SOLD 2011 Super Duty F250 6.7L - Lariat Ultimate 4x4, Black Tuxedo, Icon 2.5" Lift, Bilstein 5100's, 35x12.50 Pro Comp Xtreme Terrain on 20x9 BMF Novakane 8's.
cjf250sd11 is offline
post #2 of 7 Old 12-30-2013, 02:05 PM
im hoping those are the numbers for the 2015 I seen in diesel power magazine they guess it to be 425 875 but that could be the f450
2008 f350 6.4 powerstroke h&s black max 5inch exhaust,egr delete, bmf novakanes, nitto trail grapplers Sold 2012 cummins h&s black max 5inch straight pipe sold waiting for 2015 6.7 powerstroke
mfpowerstrok is offline
post #3 of 7 Old 01-01-2014, 09:17 AM
Quoted: 3 Post(s)
I've owned diesel cars and trucks for awhile. I never haver worked on them, just drive them. I've been reading up about the wastegate. Sounds like its a good thing for these engines. So, that being said, the current configuration has a wastegate, Ford says they are doing away with it on the new 2015 6.7L. My question is, what are the pro's and con's of Ford doing away with the wastegate on the new layout?
rrogersgsp is offline
post #4 of 7 Old 01-01-2014, 11:00 AM
99PSD-White's Avatar
Im waiting for 2018
2013 F250 Lariat 4x4 Loaded. H&S mini maxx, 5" exhaust, S&B intake, and EGR delete, AMP steps, tonneau cover
2011 F150 Ecoboost FX4 Screw. All stock except for a livernois Tuner. SOLD!
Early 99 CCLB Pro comp 6.5" lift w 18" hulk wheels wrapped in 37" KM2s, Amp steps, Straight pipe, AIS intake, Dp Tuner, isspro gauges (boost,trans,pyro), 05 front clip, traction bars, 6.0L trans cooler, built trans.SOLD!!
99PSD-White is offline
post #5 of 7 Old 01-01-2014, 11:16 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Originally Posted by 99PSD-White View Post
Im waiting for 2018
I'm waiting for 2020, by then my warranty will be up and it might just be time to see what's available. If I don't like what the Big 3 are offering, I will spend a Butt-Load of $$$ and Fix Maxie up.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 7 Old 02-19-2014, 06:41 AM
I'm new here just ordered a 15 lariat 350 anyone have any updates on vin or build weeks. Ordered 1-16-14. Thanks in advance for any info
stang77 is offline
post #7 of 7 Old 05-28-2015, 05:45 AM
I have a 2015 F250 Powerstroke 4X4. I was wondering how many miles should be showing before empty on a "full tank" of gas.
2015tigersdad is offline
