Just swapped out rear Rancho Shocks... - Ford Powerstroke Diesel Forum
post #1 of 45 Old 12-30-2013, 08:03 AM Thread Starter
For Bilstein 5100's. Now i know the "Ranchos" are branded, and basically blow, but they were COMPLETELY worn out with 40k miles on them. Zero rebound at all.
I replaced them with the 2-4" lifted 5100s, and no further than a 1/4 mile down the road could tell a huge difference!
Think I'm gonna go with 5160s for the front. I'd like to do a Fox or King res for the front but just cant see spending that kind of money for two front shocks.
Just an FYI for those who think their trucks ride rough, mine was horrible. I know its a 1 ton truck, and not a sedan, but damn, it doesn't have to jar your teeth out!!
cmb396 is offline
post #2 of 45 Old 12-30-2013, 08:23 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 65 Post(s)
rancho's, most of them, are made by teneco, who makes most white bodied shocks on the market ranging from flippin' acme labels (like the coyote used to order from) to rough country...
they are trash, by my reckoning... you are literally paying for that freaking name/sticker.. you can buy the precise same shock with somebodies house name on it for $25... or, if you must, spend $50 more for the sticker... grrrrr...
the billy's, on the other hand, are top of the line by my reckoning.. they will break in over the next several hundred miles, and you'll be loving them even more...
drewactual is offline
post #3 of 45 Old 12-30-2013, 08:27 AM
fordtrix's Avatar
Good to hear! I placed my stockers with Bilstein's 5100 as well and they definitely are an improvement, however mine weren't overly worn (about 23k miles) so I didn't get quite the same effect.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #4 of 45 Old 12-30-2013, 08:34 AM
Hoverp's Avatar
Please see my post in the Exterior section on Ranchos
Thanks Fellas!(and Gals)
2014 F350 CC Short bed, Fully loaded, Platinum Edition. 6.7L Scorpion Tuxedo Black. 3.55 ELD, FX4, Sup heater, 5th package , BFG Radial All Terrain: icon_ford:
Hoverp is offline
post #5 of 45 Old 12-30-2013, 08:35 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Congrats on swapping out the Rancho's for the Bilstein's. I went with the Rancho 9000's and Love them. Total adjustibilty for whatever the situation calls for. I do Love my Bilstein Steering stabilizer. Together, these upgrades made u Huge difference in ride quality over stock.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 45 Old 12-30-2013, 08:38 AM
Hoverp's Avatar
Stroker 8, how hard was it to do the front shock replacement? also did the Bilstein steering stab. bolt right up?
thanks
Hoverp is offline
post #7 of 45 Old 12-30-2013, 08:39 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 65 Post(s)
the higher end rancho's, such as the 9k's, are g2g, it's the white bodied mono's y'all will be wanting to avoid.. or any white bodied mono, for that matter... they are fine for a passenger car, but that's about it.
post #8 of 45 Old 12-30-2013, 08:08 PM
Long Member
TMAG6.0's Avatar
I swapped the stockers for Bilstein's too. Easy bolt up DIY mod and huge upgrade in ride quality.
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click
to save a childs life.
TMAG6.0 is offline
post #9 of 45 Old 12-30-2013, 09:32 PM
Hoverp's Avatar
Ok, ok, ok!!! I can't take it, I'm ordering 4 bilsteins 5100s.
Do you think the stock steering stab. Needs replacing?
Hoverp is offline
post #10 of 45 Old 12-30-2013, 11:27 PM
5100's
I too did the swap but my stock shocks were over 100K when I changed them. I have an 11' 250ccswb. I didn't really notice a difference. Slightly better ride, but I didn't go wow what a difference. I was shocked! Hehe. Not knocking the shocks just sayin.
southernman13 is offline
