Factory high idle - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-28-2013, 07:23 AM Thread Starter
Hoverp's Avatar
Factory high idle
So my 7.3 would go to 1100 rpm high idle pretty quick , 1-2 minutes, after I start it when it's cold out.
So far my 6.7 hasn't done it.
How about you guys on stock trucks?
2014 F350 CC Short bed, Fully loaded, Platinum Edition. 6.7L Scorpion Tuxedo Black. 3.55 ELD, FX4, Sup heater, 5th package , BFG Radial All Terrain: icon_ford:
Hoverp is offline
post #2 of 5 Old 12-28-2013, 08:14 AM
texaslimeaide's Avatar
I found out that it has to be COLD!! Like mine sat for 3 days in temps bellow 25 degrees not plugged in and when I started it, it went into high idle warm up for the first time.
2013 6.7 Powerstroke F250 XLT Crew Cab 4X4 First Owner. Amsoil OE 15W40 Diesel Motor Oil. MB Wheels and Cooper 34.5" x 12" tires.
SOLD!! 2006 F250 Lariat Crew Cab 4x2 88k miles, 4" Diamond Eye Turbo Back Exhaust, Amsoil 15W40 Synthetic Heavy Duty Diesel and Marine Motor Oil, Ea Amsoil 15k oil filter, Oil Charge Systems Amsoil Bypass Filter, SCT TSX (no custom tunes yet), Sinister Coolant Filter Kit, Zoodad Mod, Custom Diesel EGR Cooler Delete.
texaslimeaide is offline
post #3 of 5 Old 12-28-2013, 02:52 PM
I've never had mine do it either. Of course I try not to idle too much. I'd sooner just putt down the road (if you can) like a old man for a little while. It will heat up way faster then letting it idle
Jason1Pa is offline
post #4 of 5 Old 12-28-2013, 03:22 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Correctomundo! I have been doing this since August of 2011 starting with my 6.7L regular cab. No need for a sup. cab heater driving this way either.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 5 Old 12-28-2013, 06:03 PM
Mine goes on to high idle almost every time I start it lately. I'm wishing I had the supplemental heater to take the chill off, sometimes it's 20 min of driving before mine starts blowing heat...sometimes longer when it's 0* or less.
hilton850 is offline
