Should I order the OCR? Operator Command Regen! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-27-2013, 02:38 PM Thread Starter
Jquickie's Avatar
Placing my order for a new f350 xlt. I'm trying to figure out if I should order the OCR option. I tow a large fifth wheel, but I only live 5 miles from work, so I don't know if I will benefit from this option between trips when I'm just commuting to work.
Jquickie is offline
post #2 of 3 Old 12-27-2013, 03:26 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
I would say, if you want it get it. I don't personnaly have it on my own truck but I do have an edge insight cts monitor that has the option to do a manual regen plus monitor all kinds of engine functions as well as set maintanance reminder's. Good luck and enjoy.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 3 Old 12-27-2013, 04:05 PM
6.0f250firstcar's Avatar
Might as well get it. Can't hurt
Ryan
6.0f250firstcar is offline
