fricken wipers - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-26-2013, 08:49 AM Thread Starter
mario a diangelo's Avatar
fricken wipers
Last week, everytime I would use my window sprayer the wiper would just keep going til you shut the truck off. Now the bugger(being as PC as I can) comes on when you start it and just stays on, as if it was on the first int setting. I think its the switch since it started with the spray button any info?
2012 F-250 4dr shrt bed red blk leather
6.7 tuned by eric
little more then stock
2003 f-350extra cab short bed - sold
built ford tough package
4"skyjacker up front stock rear
6"stacks/black
diy boost fooler
programmed
4"custom intake
all black 20's
on 35"xtreme mt's
mario a diangelo is offline
post #2 of 3 Old 12-26-2013, 09:27 AM
Quoted: 14 Post(s)
I agree, since it started with you pushing the washer button. Probably in that assembly.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #3 of 3 Old 12-26-2013, 10:32 AM
kdskidoo's Avatar
I had the exact same issue a few weeks ago, but my problem started after I shut the truck off with the wiper switch set in the first intermittent position and the wipers in mid swipe. I tried everything to get them to turn off, but they just kept going just like as if they were set at the first position. finally I tried setting the switch to the first position and waiting for the wipers to go and then turned the truck off just like I did when I started having the problem. they've worked normally ever since.
2007 F 250 superduty Highline Pkg.
10" lift-Rock Krawler coil over 4 link pre-runner system w/ Fox res. shocks all around
dual BDS steering stabs
custom trac bars w/polished stainless inlay w/"FORD" lazer cut in center and flames on ends
Raptor coating on frame axles, etc.
bushwacker pocket style fender flares
Jesse James Lawless 18 X 10 chrome wheels
38.5 X 14.5 Pro Comp Xtreme mud tires
AMI Billet door handles and fuel door
4" turbo back stainless exhaust w/ 5" tips
much more to come
kdskidoo is offline
Tags
2012 f250 , wipers
