2015 F450 specs - Ford Powerstroke Diesel Forum
post #1 of 21 Old 12-23-2013, 08:15 PM Thread Starter
Bryce18's Avatar
Quoted: 19 Post(s)
2015 F450 specs
According to Diesel Power Mag.
Here are the 2015 F450 second generation 6.7 powerstroke
Base price- $70,000
MFG's HP at RPM- 425 hp at 2500 rpm
MFG's torque at RPM- 875 ft-lb at 1600 rpm
Axle ratio- 4:30:1
Max payload cap- 6,000 pounds
Max towing cap- 32,000 pounds
Take that and shove it Cummins! Haha
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #2 of 21 Old 12-23-2013, 09:15 PM
snobdds's Avatar
Quoted: 9 Post(s)
Those are impressive numbers...
snobdds is offline
post #3 of 21 Old 12-23-2013, 09:58 PM
Alberta Advantage's Avatar
Quoted: 19 Post(s)
Those are definitely good numbers. Well, everything but the price. If $70k is base in the US, this truck is going to be upwards of $100k in Canada. I wonder if the 450's numbers are detuned like previous years. Can't wait to see what a 250 or 350 will be pushing.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #4 of 21 Old 12-24-2013, 04:42 AM
boatpilot's Avatar
Base price- $70,000
Axle ratio- 4:30:1
How do those power claims stack up against a deleted and tuned 6.7? True dynoed numbers from our members...
2012 F350 KR
Carli 4.5 Performance, Machined Fuel Kranks 17", 37" Toyo MT's, H&S Mini with custom tunes, H&S Cac, S&B CAI, 5" FLOPRO, EGR/DPF delete, Full replacement front and rear bumpers, toolbox, and bedrails by South Texas Outfitters, Rigid LED's, B&W hitches...and this thing is finished!
boatpilot is offline
post #5 of 21 Old 12-24-2013, 05:36 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
I'm interested to know this as well. Ford claims NO more turbo lag than present setup. How does this work with a bigger turbo? I actually have very little turbo lag now, almost non-existance. When ever you add a bigger single turbo your going to have some lag, it's the nature of the beast.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 21 Old 12-25-2013, 10:03 AM
George C's Avatar
The new turbo is the same unit Ford used on the 6.0l. BIG upgrade in flow and dependability.
Everything Ford has updated with the 15' 6.7L was sorely needed.
Not only is the turbo a huge upgrade, but now there is true power potential when combining a better turbo with a stronger lift pump, and a higher volume rail and injector flow potential.
If the rods are better, I can see a tuned and deleted 6.7l in the15 model year possibly competing with a tuned 6.4l.
I am guessing 475/900 as a very easy number to start out with stock.
Sent from AutoGuide.com App
2008 F-350
KEM 345 tuned.
George C is offline
post #7 of 21 Old 12-25-2013, 02:18 PM
Quoted: 4 Post(s)
I agree George, but what about the the turbo lag theory?
btw, Merry Christmas my friend.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #8 of 21 Old 12-25-2013, 02:27 PM
Quoted: 13 Post(s)
I'm pretty sure that article said these were estimated numbers. We still have not heard anything official from Ford on what the numbers will be.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #9 of 21 Old 12-26-2013, 08:42 AM
mario a diangelo's Avatar
68k list just saw a 14 at this 250 kr
2012 F-250 4dr shrt bed red blk leather
6.7 tuned by eric
little more then stock
2003 f-350extra cab short bed - sold
built ford tough package
4"skyjacker up front stock rear
6"stacks/black
diy boost fooler
programmed
4"custom intake
all black 20's
on 35"xtreme mt's
mario a diangelo is offline
post #10 of 21 Old 12-26-2013, 06:41 PM
Quoted: 3 Post(s)
One thing I'm curious about is how many changes are being made to the F250/F350's? Everything I've read about seems to be focused on the F450. Ford looks like they are pushing a new F450 for 2015. Do you guy's know what changes are going to affect the F250 and F350?
rrogersgsp is offline
