Oil Thin and Dark - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-23-2013, 12:04 AM Thread Starter
Long Member
TMAG6.0's Avatar
Oil Thin and Dark
When checking the oil I found it unusually dark and thin. Truck had about 4000 miles on it. When changing, it poured out like crazy and had a burnt smell, very dark. A billion oil changes on my 6.0 and not one looked like that
Anyone else seeing this? Normal for the 6.7 with just 4000 miles?
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click
to save a childs life.
TMAG6.0 is offline
post #2 of 6 Old 12-23-2013, 02:49 AM
Quoted: 4 Post(s)
Fuel dilution will thin the oil. Did it reek of diesel? What weight are you running?
Sent from AutoGuide.com App
Deerhunter4 is offline
post #3 of 6 Old 12-23-2013, 03:14 AM Thread Starter
Long Member
TMAG6.0's Avatar
didnt notice any diesel smell. it smelled more burnt than anything. it was the original oil that came in the truck. i replaced it with the Rotella T6 i had left over from my 6.0
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
Click
TMAG6.0 is offline
post #4 of 6 Old 12-23-2013, 05:46 AM
mcd
Fuel in the oil, as a by product of the regen process. You will also probably notice that the truck will "make oil", due to the fuel volume.
Seems like it happens pretty quickly too. After an oil change, I notice it doesnt take long for the oil on the dipstick to get very black.
I am sure it is not good, but dont know how bad it is for the 6.7 either. I know it is pretty common, unless you are deleted.
mcd is offline
post #5 of 6 Old 12-23-2013, 07:17 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
I change my oil every 4500 miles and have never once smelled burning or had a Diesel smell. BTW, at 4500 miles, it doesn't make any oil either. I use dino oil not synthetic as I don't haul heavy loads. if your not comfortable with your oil, have it anaylized and then you will know whats going on.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 6 Old 12-23-2013, 11:20 AM Thread Starter
Long Member
TMAG6.0's Avatar
^^Good advice thanks^^ Sounds like a delete is in my near future
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
Click
TMAG6.0 is offline
