Bilstein shocks - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-23-2013, 02:45 AM Thread Starter
Bilstein shocks
I ordered a set of shocks for my 2011 f250 4x4 4wd 4door sb. I have a 2" leveling kit on the front and I told the dude at 4 wheel parts when I ordered them. Im having a he'll of a time installing them. I didn't install the leveling kit myself and I see on the bottom shock mount there looks like a 2" almost home made looking shock extension that bolts to the original shock mount and extends up about 2". Is this an add on foe the leveling kit or was it already in place because I never paid any attention to it prior to installing these shocks. I was able to get one shock on finally, but I was concerned that maybe it was to compressed with this extension in place. Im wondering if I have stock length bilstein shocks or if they are 2" longer because I ordered them for a 2" leveled truck. Now that I've confused everyone does anyone know. Thanks. Oh I ended up hooking a strap to the front bumper eye hook and lifting the truck up with my forklift to install the shock rather than fight to compress it. I was a biatch trying to get it compressed and pushed into the mount, at least it was for me.
southernman13 is offline
post #2 of 9 Old 10-23-2013, 03:23 AM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
yes that lil extension is an add on with the leveling kit... some companies IE Ready Lift do that so you can still use factory Shocks with a leveling kit. IF they sent you shocks for a truck with 2" of lift then take those off and you should be fine....
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #3 of 9 Old 10-23-2013, 03:58 AM Thread Starter
Lift
Ok thanks that's what I was thinking but not sure of. It seemed as if I was having to compress them way to far to make them work. I'll try that.
post #4 of 9 Old 10-23-2013, 07:29 AM
What's the part # for the Bilstein's you ordered? I just went through h*ll trying to get the right ones. I finally got it figured out. Apparently, Bilstein changed part numbers for the same shock I needed. I had to make a buttload of calls to figure out if the ones I received were right. I think mine were sitting in a warehouse for a while because they had a super old part #. I know more about Bilstein shocks now than I ever cared to.
SCBigJon is offline
post #5 of 9 Old 10-23-2013, 10:31 AM
Raul@Stealth Automotive's Avatar
what part numbers did they give you? we have sold alot of them in the last couple of months and noone has had any issues with them...
Raul@Stealth Automotive is offline
post #6 of 9 Old 10-23-2013, 12:39 PM Thread Starter
Shocks
I'm fix in to check, but I removed the shock extensions and was able to hook them up. They look to be correct. When I was trying with the shock extensions the bellows was all scrunched up, didn't look right.
post #7 of 9 Old 10-23-2013, 12:58 PM Thread Starter
Numbers
24-186018 and F4-BE5-C335-HO these are the numbers on the box
post #8 of 9 Old 10-23-2013, 01:20 PM
front shocks seem correct....
post #9 of 9 Old 10-23-2013, 01:30 PM Thread Starter
Shocks
Ya once I figured out I dint need the extensions I changed all four in about an hour. The nite before I spent 2 hrs and didn't even get one on. I was SHOCKED, hehe
