ABS/Hill Descent Fault Messages - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-19-2013, 10:45 AM Thread Starter
I had a Carli Suspenion leveling kit put on yesterday...put some 35x12.50s on....truck looks great...and I did not have any messages on the truck yesterday...HOWEVER, this morning I noticed the ABS light and Hill descent light came on. A hill descent Fault message and Service Autotrac message came up on the screen.....what the heck is this all about and has anyone else experienced this?
SCBigJon is offline
post #2 of 10 Old 10-19-2013, 10:45 AM Thread Starter
Btw....my truck is a 2011 F250
SCBigJon is offline
post #3 of 10 Old 10-19-2013, 10:50 AM
BigGreen06's Avatar
Quoted: 112 Post(s)
Is your computer up to date, maybe there is a flash you can get to fix the issue.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #4 of 10 Old 10-19-2013, 12:24 PM
tmd
The leveling kit and tires shouldn't be causing the fault to come on. Sounds like there may be other issues.
tmd is offline
post #5 of 10 Old 10-19-2013, 01:18 PM
the installation may have knocked a wheel speed sensor loose?
rossmelvin is offline
post #6 of 10 Old 10-21-2013, 11:40 AM Thread Starter
AH HA!!! I figured it out....the plug was disconnected....the slight height changed caused the wires to bind and when I hit a bump it must have put enough pressure on it to cause the plug to pull apart....I fixed that....thank GOD
SCBigJon is offline
post #7 of 10 Old 03-14-2014, 06:34 PM
IA Farmer's Avatar
I am getting the same warning message as you had. Where is the plug located that you fixed, I want to check that before going to the dealer?
Thanks
2013 F-350 CCSB Platinum
2010 F-250 CCSB Cabelas Edition - Sold
IA Farmer is offline
post #8 of 10 Old 03-17-2014, 03:35 PM
I'm also getting the same message and my truck won't start
2011 f-350 4x4 crew cab dually
2.5 inch lift on the front
Air bags on the back
200 hp
War hammer spartan and the dpf/cat delete
150 db - 150 psi train horn
Weather tech floor liners
Brand new flat bed
Mattress Guy is offline
post #9 of 10 Old 05-18-2014, 12:59 PM
Thanks
Where is this plug at? Please help!
SETX '14 F-250 is offline
post #10 of 10 Old 05-18-2014, 08:30 PM
IA Farmer's Avatar
I never found a plug. But did take it in and they replaced a wheel speed sensor and that fixed my problem.
Sent from AutoGuide.com App
