Mud Flaps or Fender Flares - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-17-2013, 01:35 PM Thread Starter
Debating on weather to go with one or the other. Pros and Cons would help my decision making. Thanks in advance. Note that I have already installed the aftermarket plastic wheel wells and had it under coated. I am trying make this truck last for a long time and doing what I can to delay the inevitable rust!
Odyknuck is offline
post #2 of 9 Old 10-17-2013, 03:06 PM
sagebel's Avatar
Quoted: 9 Post(s)
Fender flares won't keep everything coming off the tires off of the paint and neither will mud flaps if you are running larger tires. If you are going to stay stock I would go with mud flaps.
2012 F350 DRW King Ranch FX4
Originally Posted by nighthawk285 View Post
Pull it sideways back and forth....and don't be gentle
Originally Posted by Six0~Stroker View Post
I was just planning on running over here and whipping it out. Sent from
sagebel is offline
post #3 of 9 Old 10-17-2013, 03:49 PM
layson's Avatar
Quoted: 81 Post(s)
I would agree. Plus a lot of times fender flares will actually do more harm than good to the paint.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #4 of 9 Old 10-17-2013, 06:15 PM
Beware of the Ford molded plastic flaps.
These will rub the paint off the outside of your wheelwells.
I ran them about a year and the paint was gone.
Never would have noticed if I hadn't removed them to install different flaps for wider rims and tires.
XR250R is offline
post #5 of 9 Old 10-17-2013, 07:04 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
Look into Dura Flap mudflats. Been using them for a few years now with no issues. No rips or tears and they don't look like they've been beaten by the mud, rain, snow, and slush.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #6 of 9 Old 10-18-2013, 05:56 AM
If you are going to be in a lot of mud or snow the flaps may get ripped off or damaged. I use Duraflaps to keep rocks from hitting my RV and they work well but I don't get into mud or snow.
Oversized tires would do better with flares I think.
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #7 of 9 Old 10-18-2013, 08:45 AM Thread Starter
I have no plans to run larger tires. When I replace the OEMs I may g up one size however still within the wheel well. I am looking for stone chip protection. I am considering the flares as they appear to cover the metal wheel well flange. My concern with either is the trapping of salt behind them contributing to the rust that I am trying delay. This truck will only be driven 3 to 4,000 miles a year at best to tow my Toy hauler for off roading. The plan is to keep it for at least 12 years. Yea I know that's pretty funny!
Odyknuck is offline
post #8 of 9 Old 10-18-2013, 08:55 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Has anybody tried that spray on ,clear paint protection stuff that you can just peal off and re- apply?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 9 Old 10-18-2013, 01:43 PM
I went with OEM fender flares because their held on with 3M tape that adhere to your fender as well as screws in the wheel well. I kept reading about the aftermarket fender flares and they all appear to have a rubber seal that rests against your fender, which traps dirt and debris and eventually leads to paint rubbing. OEM fender flares with the 3M tape protects the paint a little better (IMO).
Then I installed the OEM molded mud flaps that secure over the fender flare. Sure, it'll trap dirt and likely rub the paint. but, I like the looks of the molded flaps and worst case scenario; it's rubbing paint on a plastic parts and won't be noticed unless I remove the flaps.
I've been thinking of removing the mud flaps and spraying that small area will clear plast-dip and then re-installing the mud flap. This might help protect the paint on the fender flare.
Here is the thread on my fender flare install after I found some factory take-off on eBay: http://www.powerstroke.org/forum/6-7...e-install.html
2012 F-250 Lariat FX4 Ultimate/Chrome Package, CC SB 3.55 ELD, Clearance Lights, Rapid Heat, Upfitters, HD Alternator, Snow Plow Prep, PTO, Husky Liners, Arma Spray-in Bed Liner, Bakflip F1 Tonneau, BFGoodrich All-Terrain T/A 325/65/R18 on Stock 18's
AK250 is offline
